mismatch between routing and pim RPF
yuhuiyao
All,
I have the following on my router. Router A has two pathes to RP, one is from s1/3 (NH 14.0.0.4), the other is from s1/0 (NH 12.0.0.2). There seemed to have a split decision on routing and rpf. Routing chooses s1/0 (NH 12.0.0.2) while RPF chooses s1/3 (NH 14.0.0.4) Can anyone let me know why?
A#show ip rpf 3.3.3.3
RPF information for ? (3.3.3.3)
  RPF interface: Serial1/3
  RPF neighbor: ? (14.0.0.4)
  RPF route/mask: 3.3.3.3/32
  RPF type: unicast (ospf 65000)
  RPF recursion count: 0
  Doing distance-preferred lookups across tables
A#show ip ro 3.3.3.3
Routing entry for 3.3.3.3/32
  Known via "ospf 65000", distance 110, metric 129, type intra area
  Last update from 14.0.0.4 on Serial1/3, 00:54:28 ago
  Routing Descriptor Blocks:
    14.0.0.4, from 3.3.3.3, 00:54:28 ago, via Serial1/3
      Route metric is 129, traffic share count is 1
  * 12.0.0.2, from 3.3.3.3, 00:54:28 ago, via Serial1/0
A#show ip cef
A#show ip cef ex
A#show ip cef exact-route 1.1.1.1 3.3.3.3
1.1.1.1         -> 3.3.3.3        : Serial1/0 (next hop 12.0.0.2)
2 Accepted Solutions
Lei Tian
From your show ip route output, I can see you have 2 equal path for that prefix. On that case, PIM will use the PIM neighbor with higher IP as the RPF neighbor. Please check the link
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6552/ps6592/whitepaper_c11-474791.html
HTH,
Lei Tian
Giuseppe Larosa
Hello Yuhui,
this is a typical situation with PIM.
unicast routing supports load balancing and install two routes of equal cost.
sh ip cef exact-route provides the exit interface that would be used given a flow with specific SA and specific DA, so one link of the two is used.
CEF uses an exor of IP SA, IP DA and an hash seed to calculate the exit link
the choice of RPF interface is made looking for a single best path to reach the source (or the RP)
in case of links with similar AD, metric the link with highest ip address is chosen.
On some platforms, a command allows to relax the RPF check and to support multiple paths
ip multicast multipath
see
http://www.cisco.com/en/US/docs/ios/ipmulti/command/reference/imc_03.html#wp1058784
if multicat traffic with source 3.3.3.3 would be received on interface ser1/0 instead of ser1/3, it would be seen as an RPF failure without the above command.
Hope to help
Giuseppe
7 Replies 7
Lei Tian
HTH,
Lei Tian
Thanks all for your reply. Is there a way to tell the router prefer the lower ip as an RPF neighbor instead of chaning ip addresses?
If you want PIM to prefer the lower IP path, you can
1 change the unicast routing cost, OSPF on your case to prefer one path over the other; that will break your unicast routing.
2 configure a static mroute and use the lower IP neighbor as the next hop; that will not break your unicast routing.
http://www.cisco.com/en/US/docs/ios/12_3/ipmulti/command/reference/ip3_i1g.html#wp1073735
A static mroute will have AD = 1, and it will be preferd over OSPF.
HTH,
Lei Tian
All,
I have static mroute defined, pointing toward 13.0.0.1. However the rpf neighbor still points toward 34.0.0.3. Any idea why?
D#show ip rpf 3.3.3.3
  RPF interface: Serial1/4
  RPF neighbor: ? (34.0.0.3)
D#
D#show ip mroute static
Mroute: 3.3.3.3/32, RPF neighbor: 13.0.0.1
  Protocol: none, distance: 0, route-map: none
D#
Hi Yuhui,
Looks like it doesnt use the static mroute. Is the next hop 13.0.0.1 reachable on your router? What's the pim neighbor do you have on that router?
HTH,
Lei Tian
There is a typo. Problem solved. Thanks.
Giuseppe Larosa
Hello Yuhui,
see
Hope to help
Giuseppe
