03-22-2024 01:50 AM
We want to create DMVPN tunnel by using C8200-1N-4T.
We have activated network and dna licenses, but when we try crypto commands, there is no choice for Diffie-Hellman group 2.
C8200 is currently showing below DH-group
Router(config-isakmp)#group ?
14 Diffie-Hellman group 14 (2048 bit)
15 Diffie-Hellman group 15 (3072 bit)
16 Diffie-Hellman group 16 (4096 bit)
19 Diffie-Hellman group 19 (256 bit ecp)
20 Diffie-Hellman group 20 (384 bit ecp)
21 Diffie-Hellman group 21 (521 bit ecp)
Our DMVPN hub is using DH group 2, so I guess we need to figure out how to activate DH group 2 on C8200.
Is there something I'm missing?
Solved! Go to Solution.
03-22-2024 02:47 AM
Yes you can config multi ISAKMP policies in Hub and Spoke with DH 14 will accept the second one and other spokes run old DH 2 will accept the first policy
MHM
03-22-2024 02:27 AM
I think new Cisco Device not support DH group 2 anymore
you need to config Hub to accept DH group list in your spoke
MHM
03-22-2024 02:44 AM
Hi MHM,
Thanks for the info.
So when accepting new dh group on the hub, will adding another isakmp policy works?
Or do we need to add dh group on the exisiting isakmp policy?
<example>
■Current config
crypto isakmp policy 1
encr aes
authentication pre-share
group 2
■What we want to do
encr aes
group 2
crypto isakmp policy 2
encr aes
group 14
03-22-2024 02:47 AM
MHM
03-22-2024 02:44 AM
dh group 2 has been deprecated since 7.0 (possibly 6.7) along with IKEv1 - since it is hideously insecure. You really need to look at the hub to see if that can accept a modern IKEv2 configuration with modern dh groups (19,20,21,31,...) [not all Cisco kit can yet do dh31, but some can already]
03-07-2025 05:04 PM
Device(config)#crypto engine compliance shield disable
This will enable lower encryption method
