12-17-2019 05:41 AM
Hello, No eigrp routes passing from R7 to SW2 , here is the config for your view.
SW-2#sh ip eigrp neighbors
EIGRP-IPv4 VR(vpn) Address-Family Neighbors for AS(267)
H Address Interface Hold Uptime SRTT RTO Q Seq
(sec) (ms) Cnt Num
1 10.2.7.7 Fa0/1 6 02:25:47 68 408 0 5
0 10.2.6.6 Fa0/0 13 02:25:47 48 288 0 5
SW-2#sh run | sec router eigrp
router eigrp vpn
address-family ipv4 unicast autonomous-system 267
topology base
redistribute connected
exit-af-topology
network 10.0.0.0
network 10.2.7.2 0.0.0.0
exit-address-family
SW-2#sh ip route eigrp
Gateway of last resort is not set
R7#sh run | sec router eigrp
router eigrp PE
address-family ipv4 unicast vrf L3VPN autonomous-system 267
topology base
exit-af-topology
network 10.2.7.7 0.0.0.0
net 7.7.7.7 0.0.0.0
exit-address-family
R7#sh ip eigrp vrf L3VPN neigh
EIGRP-IPv4 VR(PE) Address-Family Neighbors for AS(267)
VRF(L3VPN)
(sec) (ms) Cnt Num
0 10.2.7.22 Fa0/1 13 02:28:08 42 252 0 8
Solved! Go to Solution.
12-17-2019 06:05 AM - edited 12-17-2019 06:07 AM
Because there is only one interface whitin vrf L3VPN that is used to peer eigrp neighborship, try to input ip vrf forwarding under loop0 that it can be send this to SW trough eigrp
12-17-2019 05:54 AM
@feroz syed Hello
Is there a interface with this network net 7.7.7.7 0.0.0.0 under vrf L3VPN?
please post here output from on R7
show ip int bri
show ip vrf
12-17-2019 06:00 AM
R7#sh run
Building configuration...
Current configuration : 1755 bytes
! Last configuration change at 14:17:43 UTC Tue Dec 17 2019
version 15.2
hostname R7
boot-start-marker
boot-end-marker
vrf definition L3VPN
rd 100:100
route-target export 100:100
route-target import 100:100
address-family ipv4
exit-address-family
no aaa new-model
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
mpls label range 700 799
ip tcp synwait-time 5
interface Loopback0
ip address 7.7.7.7 255.255.255.255
interface FastEthernet0/0
ip address 10.5.7.7 255.255.255.0
speed auto
duplex auto
interface FastEthernet0/1
vrf forwarding L3VPN
ip address 10.2.7.7 255.255.255.0
speed auto
duplex auto
interface Serial1/0
no ip address
shutdown
serial restart-delay 0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router eigrp PE
topology base
exit-af-topology
network 7.7.7.7 0.0.0.0
exit-address-family
router ospf 1
router-id 7.7.7.7
network 7.7.7.7 0.0.0.0 area 0
network 10.5.7.7 0.0.0.0 area 0
mpls ldp autoconfig
ip forward-protocol nd
no ip http server
no ip http secure-server
mpls ldp router-id Loopback0
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
12-17-2019 06:04 AM - edited 12-17-2019 06:04 AM
Well, could you try it:
interface Loopback0
ip vrf forwarding L3VPN
12-17-2019 06:04 AM
12-17-2019 06:08 AM
