Missing EIGRP Routes
mudvayne15
hello everyone,
I am trying to reach our server to the cloud on 10.65.120.0 network however I am not able to reach it via our remote offices. Though I am able to reach 10.65.1.0 network anywhere.
I noticed on the EIGRP topology, it does not include the 10.65.120.0 network. Is there anything I am missing on my network command? I tried to add 10.65.120.0/21 on EIGRP but no luck. I still cannot see the route from remote office.
#show ip bgp nei x.x.30.209 received-routes
BGP table version is 20152948, local router ID is 10.2.2.10
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 10.65.1.0/24 x.x.30.209 100 0 64512 i
*> 10.65.120.0/21 x.x.30.209 100 0 64512 i
EIGRP Network config below
router eigrp 89
redistribute static
network 10.0.0.0 0.0.0.3
network 10.65.20.0 0.0.0.255
network 10.65.21.0 0.0.0.255
network 10.255.255.0 0.0.0.3
network 10.255.255.12 0.0.0.3
network 10.255.255.16 0.0.0.3
network 10.255.255.64 0.0.0.3
network 10.255.255.72 0.0.0.3
network 10.255.255.80 0.0.0.3
network 10.255.255.100 0.0.0.3
network 10.255.255.104 0.0.0.3
network 10.255.255.116 0.0.0.3
network 10.255.255.120 0.0.0.3
network 10.255.255.148 0.0.0.3
network 10.255.255.152 0.0.0.3
no auto-summary
ip route 10.65.0.0 255.255.240.0 Tunnel10 track 101
ip route 10.65.0.0 255.255.240.0 Tunnel11 track 201
ip route 172.31.0.0 255.255.0.0 Tunnel650101 track 201
ip route 10.75.0.0 255.255.224.0 Tunnel3 track 300
ip route 10.65.32.0 255.255.224.0 Tunnel3 track 300
ip route 10.75.0.0 255.255.224.0 Tunnel4 track 400
ip route 10.65.0.0 255.255.240.0 Tunnel10 track 400
ip route 172.31.0.0 255.255.0.0 Tunnel650100 track 500
ip route 0.0.0.0 0.0.0.0 116.214.96.193
ip route 10.20.0.0 255.255.0.0 Tunnel6500101
ip route 10.61.0.0 255.255.0.0 Tunnel63
ip route 10.65.0.146 255.255.255.255 198.18.124.5
ip route 10.65.4.0 255.255.255.0 198.18.124.5
ip route 10.65.21.0 255.255.255.0 10.65.20.1
ip route 10.65.22.0 255.255.255.0 10.65.20.1
ip route 10.65.25.0 255.255.255.0 10.65.20.1
ip route 10.65.26.0 255.255.255.0 10.65.20.1
ip route 10.65.27.0 255.255.255.0 10.65.20.1
ip route 10.65.29.0 255.255.255.0 10.65.20.1
ip route 10.65.30.0 255.255.255.0 10.65.20.1
ip route 10.65.31.0 255.255.255.0 10.65.20.1
ip route 10.65.128.0 255.255.128.0 198.18.124.5
ip route 10.86.0.0 255.255.0.0 10.65.20.1
I suppose the 10.65.0.0/19 should cover for all the subnets but it doesn't.
#show ip eigrp topology | i 10.65
P 10.65.0.0/19, 1 successors, FD is 2816
P 10.65.4.0/24, 1 successors, FD is 28160
P 10.65.27.0/24, 1 successors, FD is 2816
P 10.65.26.0/24, 1 successors, FD is 2816
P 10.65.25.0/24, 1 successors, FD is 2816
P 10.65.31.0/24, 1 successors, FD is 2816
P 10.65.30.0/24, 1 successors, FD is 2816
P 10.65.29.0/24, 1 successors, FD is 2816
P 10.65.22.0/24, 1 successors, FD is 2816
P 10.65.21.0/24, 1 successors, FD is 2816
P 10.65.20.0/24, 1 successors, FD is 2816
P 10.65.32.0/19, 1 successors, FD is 297244416
P 10.65.128.0/17, 1 successors, FD is 28160
P 10.65.0.146/32, 1 successors, FD is 28160
Giuseppe Larosa
Hello @mudvayne15 ,
if the missing prefix 10.65.120.0/21 is learned in BGP you need to redistribute it into EIGRP
ip prefix-list BGP-ROUTE permit 10.65.120.0/21
route-map BGP-TO-EIGRP permit 10
match ip address prefix BGP-ROUTE
set metric 10000 100 255 1 1500
router eigrp 89
redistribute bgp <your-BGP-ASnumber> route-map BGP-TO-EIGRP
In EIGRP a seed metric is needed providing its components where the last one is the MTU.
This is done in the route-map alternatively you could set a default-metric at EIGRP process level.
Hope to help
Giuseppe
Thanks for the help, I used your suggestion and it worked fine
ping 10.65.122.31 so 10.63.11.2
Sending 5, 100-byte ICMP Echos to 10.65.122.31, timeout is 2 seconds:
Packet sent with a source address of 10.63.11.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 76/78/84 ms
Though my other question is, why the other subnet 10.64.1.0 from BGP is reachable. Is it because of the static route 10.65.0.0/19 redistributed in EIGRP?
Hello @mudvayne15 ,
I'm happy it worked for you.
yes your understanding is correct that subnet 10.65.1.0 is covered by 10.65.0.0/19
Hope to help
Giuseppe
