MLPPP limitations
sukirin
dear all,
i have 2 module contain 4 serial each. with total of 8 serial.
i am configuring MLPPP to bundle all 8 serial interface into 1 bundle.
but, the problem is the traffic only pass through to 4 of the serial.
is there a limitation for MLPPP on 3825?
Adam Frederick
Level 3
Level 3
You should be able to use 8 sync/async interfaces no problem for MLPPP on a 3825. Are the only 4 interfaces passing traffic on one module or are interfaces on each module passing traffic?
only the 1st 4 passing traffic.
if there is no configuration problem, i want to know wheter it is a hardware limitation of 3825 / IOS limitation ?
if there is no such hardware limitation then i have to recheck my configuration :P
sukirin
Can you post the output of show interface for the links that are working and for the links that are not working? Perhaps also the output of show cdp neighbor?
If you can not find a problem with the interfaces that are not working then probably you need to look at your config. Perhaps you can post the config so that we can look at it also.
Rick
Rick
