Modules on ASR
Ibrahim Jamil
Level 6
Level 6
Hi Netpro
how to show all  the module on the ASR 1004?
thanks
5 Replies 5
acampbell
Try this
Cisco ASR 1000 Series Aggregation Services Routers
show diag [all | chassis | slot | subslot] eeprom
show platform
I used this link
http://www.cisco.com/en/US/docs/ios-xml/ios/interface/command/ir-cr-book.html
Alex
Regards, Alex. Please rate useful posts.
Hi Alex
I got "Forbiden Application"
     Pls can u doenload and submit it
can u help me to administer a BGP Router connected to 2 different ISPs we r ucing public real as
thanks
I dont know why you cant see the HTML link.
I am attaching the PDF
Alex
thanks alex
Brett Rabang
I believe you have to specify on CLI 'card type' and then you will be able to see the serial interfaces. I ran into this same thing when I was installing a t3 sub module.
