Modules with a +
dodgerfan78
Aplogies if this is not a WAN topic...
What is the difference between a PA-T3 and PA-T3+. I have looked at the module guides but can seem to come across a real difference. I basically want to know if I can replace a PA-T3+ with a PA-T3.
If there is a better forum for this type of topic, please let me know.
Thank you.
5 Replies 5
paolo bevilacqua
The + version had few improvements, like supporting more combination of scrambling/dsu modes/bandwith.
Beside that you should be able to use either.
Thank you. Do you think it would it be supported in a VIP4-80? The only quote I can find is "The VIP4 is fully compatible with most Cisco 7500/7200 PAs." It says "most" but not "all" which concerns me. I can't find a list of supported modules for the VIP4-80. Do you know a link?
These were kind of obscure info even when I was working there in the same building engineering was.
All can I say try and good luck, sorry can't help you better.
Phillip Remaker
PA-T3+ added Subrate T3 support, greater compatability to other DSUs, and allegedly a better analog interface.
http://puck.nether.net/lists/cisco-nsp/0374.html
http://puck.nether.net/lists/cisco-nsp/12261.html
Google "PA-T3 PA-T3+ required" and "PA-T3 PA-T3+ difference" for more details.
Thank you! I did check out the commands that were enabled on the +, and they existed on the regular so I figured it would work, but I wanted to be sure. I ran into a problem a while back where a PA-4T wasn't suppoprted in a FlexWAN while the PA-4t+ was. I didn't want to run into that issue again with the PA-T3. While scrounging through our warehouse I did find a spare PA-T3+ so I am all good   Thanks both of you for the help.
