Monitor comunication tcp
pesanchez2002
how i can monitor the comunication tcp:
- ack
- seq
- windows
- fin
With wireshark, and to do troubleshooting and
to determine if i have any problem
Giuseppe Larosa
Hello Pedro,
first of all you need to mirror traffic o the PC NIC using some form on SPAN on a LAN switch.
then on wireshark after the capture you can select one frame of the TCP session and you can use the option called follow TCP stream it will open a child window trying to rebuild the TCP session
Hope to help
Giuseppe
