monitor the Internet activity
Ibrahim Jamil
Level 6
Level 6
Hi Experts
How can i monitor the Internet activity in my network so see the users performs heavy download , in fact  the Internet utilization on my link all time are full; we have asa 5510 perform NAT along with 2600 router as gateway connect us to the isp
Pls Help
thanks
Jamil
8 Replies 8
cadet alain
where should i configure this? on Internet router f0/0  connected to isp?
thanks
In the past based on the document below I have configured Netflow on the inside interface of the Internet router. This is the interface that connects your router to your switch.
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6555/ps6601/prod_white_paper0900aecd80406232.html
Hi Sean
my inside interface or my router(Public IP) connected to outside interface of cisco asa(outside interface Public ip)
outside interface of my router connected to isp,
pls help me to acheive with  the config as per the above topology
thanks
jamil
Here is a link to configure netflow
http://www.cisco.com/en/US/docs/ios/12_1/switch/configuration/guide/xcdnfc.html
Place this on the router not the ASA.  The flow will then be applied to the exit interface on the router that is connected to the ASA.  Then any traffic outbound through the ASA will be cached and data collected for netflow
Hi Rick
do u mean on router inside interface wich have a Public IP ?
do u have a video on somewhere else to master this stuff?
thanks
You would apply this to the interface connected to your internet segment
http://www.youtube.com/watch?v=jf3ZKTU3l68
This will walk you through a set-up and where.
If you have a Ethernet handoff from the ISP then you will apply to the Ethernet interface connected there.  You would not do any inside interface.  This is for WAN, not to assume that you cannot do netflow on your LAN.
thanks rick
