MP-BGP on a middle PE
Mohammad Nasim
Hello everybody,
I have the following topology. Network A needs to talk to Network B.
I created Customer VRF on the middle PE (PE-X) and I successfully saw the routes from both sides, however Network A still cannot ping network B. also, traceroute shows astrisks.
I got a solution by enabling address-family vrf CustomerX under MP-BGP.
Can anybody explain why this solved the problem?
9 Replies 9
Harold Ritter
 Are network A and network B the only two networks you advertise? If so, make sure use them as the source when you ping the other side (ie. ping <network B> source <network A> and vice versa.
You mean enabling it on PE-X?
By the way, did you configure as a route-reflector for address-family vpnv4?
Thank you Harold.
Yes, I am sure of the ping's source.
and Yes, I mean enabling "address-family ipv4 vrf Customer" on PE-X.
By the way, it is not a router.
PE-1 is an ASR
PE-2 and PE-X is a nexus N7K.
So, the correct syntax is:
router bgp 65000
 vrf Customer
  address-family ipv4 unicast
Hi Mohammad,
You do not need to enable "address-family ipv4 vrf Customer" on PE-X, unless there are actually local customers belonging to that VRF.
On the other hand, Do you have a direct VPNv4 session between PE1 and PE2 or do PE1 and PE2 only have a BGP session to PE-X? If so, PE-X needs to reflect VPNv4 routes from PE1 to PE2 and vice versa, in which case it needs to be configured as a route reflector for that address family.
Yes, and that is why I am asking for explanation.
 Yes, there is a full mesh BGP session for both IPv4 and VPNv4.
Can you confirm that LDP sessions are up between PE1 and PE-X and between PE2 and PE-X?
LDP sessions between PE-1 and PE-x AND PE-2 and PE-x are up for weeks.
Actually, this is not the first abnormal behavior between Nexus and ASR.
I have very strange cases. For example, BGP will never install routes in the routing table unless the bgp neighbor is learned via EIGRP. However, routes are there in BGP table. Static routing and OSPF makes BGP stuck and reject all routes. This is a very strange behavior.
ASR itself, has many GP session with other routers. It is stable.
Nexus itself, has another BGP session with another Nexus and BGP neighbor is learned via OSPF. No problem at all.
Only Nexus and ASR shows misbehavior.
Could you please post the configuration for PE1, PE-X and PE2.
Actually, it is a classified information that i cannot expose without customer permission. However, I will establish a lab with c7200 routers to simulate the case and post the configuration.
I am sure, c7200 will work correctly, as the problem is between nexus and ASR.
The purpose of the lab is to show you how devices are configured, but not to replicate the behavior.
Give me some time, and I will reply back to this thread.
In the meantime, it would be useful to do a "show ip cef vrf <vrf-name> <network a> det" from PE1 and vice versa on PE2 in the customer network to verify that the label stack is fine.
