MPLS Failover
Peter K
I have an requirement. My HUB location has dual MPLS links from two different service providers. Spoke locations also has dual links from same
service Providers. My requirement is to enable auto fail over between HUB and SPOKE. Currently using Static routing at both ends.
Both links must be in active active to handle traffic (assuming any one link fails in spoke, it should access HUB through the other link.
Which protocol can be used at HUB and Spoke.
Hi Peter. You can run BGP between PE to CE in you hub and spoke and run any IGP proocol like EIGRP, OSPF between CE to your L3.
Peter K
can someone help?
Thanks.can you provide the BGP configuration at HUB end.
