MPLS not working on new Eth link.
johnelliot6
Level 2
Level 2
We have recently provisioned a new p-t-p(eth) link between our cores for redundancy - The provider of the new link is currently filtering multicast, so ospf needed to be configured as unicast until they rectify the problem.
I have enabled mpls on the new link, and it is showing as active (sh mpls int on both R1+R3) but it is not showing up as an active neighbour.
Could the ospf multicast issue also be causing mpls problems?
#sh mpls interfaces
Interface              IP            Tunnel   Operational
Port-channel1.927      Yes (ldp)     No       Yes
Port-channel1.86       Yes (ldp)     No       Yes        <--- New link
#sh mpls ldp neighbor
    Peer LDP Ident: 10.0.76.249:0; Local LDP Ident 10.0.76.238:0
        TCP connection: 10.0.76.249.42950 - 10.0.76.238.646
        State: Oper; Msgs sent/rcvd: 84353/84479; Downstream
        Up time: 6w2d
        LDP discovery sources:
          Port-channel1.927, Src IP addr: 10.0.66.174
R1 has p-t-p link to R2(Working ospf+mpls), and new p-t-p link to R3(Working ospf(Unicast), not working mpls)
R1
interface Port-channel1.927
description Link_to_R2
encapsulation dot1Q 927
ip address 10.0.66.173 255.255.255.252
ip ospf message-digest-key 10 md5 7 141314134D57787A
ip ospf cost 100
ip ospf mtu-ignore
no snmp trap link-status
mpls ip
mpls mtu 1530
end
interface Port-channel1.86
description Link_to_R3
encapsulation dot1Q 86
ip address 10.0.66.1 255.255.255.252
ip ospf network non-broadcast
ip ospf cost 80
mpls ip
mpls mtu 1530
end
R2
interface GigabitEthernet0/1.927
description Link_to_R1
ip address 10.0.66.174 255.255.255.252
ip ospf cost 100
ip ospf mtu-ignore
mpls ip
mpls mtu 1530
R3
ip address 10.0.66.2 255.255.255.252
ip mtu 1500
ip ospf cost 80
mpls mtu 1530
mpls ip
Thanks in advance.
Reza Sharifi
LDP hello exchange uses multicast address 224.0.0.2
Can you do a "debug mpls ldp transport connections"?
This comand should tell you if hellos are being exchanged between the 2 routers.
Reza
Reza Sharifi
Reza
Thanks Reza - Looks like I have an issue then if it requires multicast(Until provider fixes this)
debug output, I only see:
R1:
Dec 14 10:26:05.914 aest: ldp: Scan listening TCBs
Dec 14 10:27:05.946 aest: ldp: Scan listening TCBs
Dec 14 10:28:05.974 aest: ldp: Scan listening TCBs
Dec 14 10:29:06.002 aest: ldp: Scan listening TCBs
R3:
Dec 14 10:30:19.951 AEST: ldp: Scan listening TCBs
Dec 14 10:30:29.896 AEST: ldp: Data received!
Dec 14 10:30:35.552 AEST: ldp: Data received!
Dec 14 10:31:15.503 AEST: ldp: Data received!
Dec 14 10:31:19.955 AEST: ldp: Scan listening TCBs
Dec 14 10:31:28.016 AEST: ldp: Data received!
Dec 14 10:32:14.103 AEST: ldp: Data received!
Thanks again
Hi John,
Can you do a:
T-1#debug mpls ldp transport events
Below output is from my 2 routers connect via LDP.
LDP transport events debugging is on
T-1#
*Dec 14 02:47:52.460: ldp: Send ldp hello; GigabitEthernet0/1, src/dst 172.16.0.14/224.0.0.2, inst_id 0
*Dec 14 02:47:52.460: ldp: Rcvd ldp hello; GigabitEthernet0/1, from 172.16.0.13 (10.0.3.3:0), intf_id 0, opt 0xC
*Dec 14 02:47:56.836: ldp: Send ldp hello; GigabitEthernet0/1, src/dst 172.16.0.14/224.0.0.2, inst_id 0
*Dec 14 02:47:56.860: ldp: Rcvd ldp hello; GigabitEthernet0/1, from 172.16.0.13 (10.0.3.3:0), intf_id 0, opt 0xC
*Dec 14 02:48:00.980: ldp: Rcvd ldp hello; GigabitEthernet0/1, from 172.16.0.13 (10.0.3.3:0), intf_id 0, opt 0xC
*Dec 14 02:48:01.156: ldp: Send ldp hello; GigabitEthernet0/1, src/dst 172.16.0.14/224.0.0.2, inst_id 0
T-1#sh mpl ldp neighbor
    Peer LDP Ident: 10.0.3.3:0; Local LDP Ident 130.130.0.1:0
        TCP connection: 10.0.3.3.646 - 130.130.0.1.26088
        State: Oper; Msgs sent/rcvd: 200/170; Downstream
        Up time: 00:27:15
          GigabitEthernet0/1, Src IP addr: 172.16.0.13
        Addresses bound to peer LDP Ident:
          10.0.4.1        10.0.2.5        172.16.0.13     10.0.4.13
Reza
Hi Reza,
With debug mpls ldp transport events enabled, I see R1+R3 sending ldp hellos on the new link, but no rcvd's - So it looks like the filtering of multicast is causing my mpls issues(As you stated).
Thanks.
