03-16-2009 12:35 AM - edited 03-04-2019 03:56 AM
After an upgrade to 12.4.24T has "ip mpls" and "address family vpnv4" disappeared from configuration. I couldn't find any documentation on CCO which explanins how to configure VPN on 1801 router with 12.4.24T advipserv.
Thanks for any tips.
03-16-2009 06:13 AM
Hello Daniel,
the feature navigator
for 1801 adv ip services 12.4(24)T doesn'list any MPLS feature
use search by platform specify IOS 1801 and then select 12.4T the release 24
you need an upgrade to advanced enteprise to get MPLS and MPLS VPN functionality
Hope to help
Giuseppe
03-16-2009 07:00 AM
Hi Giuseppe,
I've just testet with:
Cisco IOS Software, C180X Software (C180X-ADVENTERPRISEK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
But under interface configuration there is no option for mpls, as did for release prior to 12.4(20).
ROUTER209(config-if)#int tu0
ROUTER209(config-if)#m?
mac-address macro max-reserved-bandwidth
Neither for bgp adress-family vpnv4
ROUTER209(config)#router bgp 100
ROUTER209(config-router)#address-family ?
ipv4 Address family
ipv6 Address family
//daniel
03-16-2009 08:21 AM
Hello Daniel,
this is a case of missing information in feature navigator.
IF you haven't a compelling reason to stay in 12.4(24)T you may consider a downgrade to a version supporting MPLS and MPLS VPN.
At the same time you can open a TAC service request to signal the lack of functionality in advanced enterprise image 12.4(24)T.
Hope to help
Giuseppe
