Join Customer Connection to register!
223
patrickorr5773
Beginner
MPLS WAN SLA/TRACKING Inquiry
Please look at the attached network diagram.  The assumptions are as follows:
Each site has an internal LAN with the gateway being the HSRP VIP for each set of routers.
Each site has an independent MPLS provider connection going into each router.
MPLS connection A has a higher priority in the HSRP config on each router than B.
The two routers at each site discover each other within the lan as BGP neighbors.
The next MPLS hops from G0/0/0 on each router are the same subnet just .1 instead of 2.
I would like to do Tracking/SLA so that if MPLS connection A goes down at any one site EVERY site will switch to MPLS provider B not just that single one.
I would assume Boolean tracking would most likely the best solution for this.
Inputs or thoughts?  I haven't been able to make them all swing at once like I want.
0 REPLIES 0
