msfc
rajivrajan1
Level 3
Level 3
hi guys,
I got a msfc switchover in my 6500 (hybrid - System Bootstrap Version: 5.3(1)
and msfc image is (C6MSFC2-PSV-M), Version 12.1(13)E5, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Only MSFC got switchover not SUP
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X6K-SUP1A-2GE yes ok
15 1 1 Multilayer Switch Feature WS-F6K-MSFC2 no standby
2 2 2 1000BaseX Supervisor WS-X6K-SUP1A-2GE yes standby
16 2 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
3 3 48 10/100BaseTX Ethernet WS-X6148-RJ-45 no ok
4 4 48 10/100BaseTX Ethernet WS-X6148-RJ-45 no ok
So I want to reset the MSFC back to primary SUP.
Normal reset will give 30-40 secs downtime.
SSO is not available in this software version.
any other suggetions would be helpful if i could do it without down time.
ankbhasi
Hi Ravi,
Unfortunately there is no workaround for the same. Without SSO there is no way to reduce the switchover time.
Ankur
paolo bevilacqua
Give that you have to reload, why not load latest software. So you will have the new features and fixes.
