12-30-2005 02:07 AM - edited 03-03-2019 11:19 AM
Hi All
I am looking at issues with convergence on ring of 3550 / 3750.
What is the limit of switches that can be put on a ring topology ? I am not sure but my issues seems to be related to number of trunks, each time I add a trunk convergence times increases.
Any thoughts....before I segment the ring.
As a side mote, looking after this issues has cost me the nickname of Frodo Baggins.
TIA
Cisco Lad
12-30-2005 07:24 AM
AFAIR, Frodo Baggins eventually destroyed the big bad Sauron and saved the world ? So that nickname does not sound too bad, I'd say...
When you say 'ring', does that mean your topology looks like this ?
Swicth1 --> Switch2 --> Switch3 --> Switch4 --> Switch1
In general, the maximum spanning tree diameter, as defined by the IEEE, is seven, how many switches do you have ? Can you maybe draw out your physical setup and post it here ?
GP
01-02-2006 03:30 AM
Hey Georg
Long time, no speak.
7 switches only applies to STP, I am running MSTP and I think the limitation is 20. I currently have 16 in total. I can of course change the timers, but do not dare as all state bodies and high end corporate are serviced on this metro ring.
Tia
Sam
