01-26-2020 04:44 AM
Hi all,
we are running many CISCO886VA-SEC-K9 on german ADSL lines. Currently we are running this IOS: 154-3.M8
Our config is basic:
interface ATM0 no ip address no atm ilmi-keepalive ! interface ATM0.7 point-to-point mtu 1600 pvc 1/32 bridge-dot1q encap 7 pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
dialer pool 1
With this config we are able to ping our LNS with 1492 Byte:
Router#ping 2.17.0.163 size 1492 df-bit Type escape sequence to abort. Sending 5, 1492-byte ICMP Echos to 2.17.0.163, timeout is 2 seconds: Packet sent with the DF bit set !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 32/32/36 ms Router#
After upgrading IOS to 15.7(3)M5 max. packet size is now 1474 Byte.
Router#do ping 2.17.0.163 size 1474 Type escape sequence to abort. Sending 5, 1474-byte ICMP Echos to 2.17.0.163, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 32/32/32 ms
Router#
Router#do ping 2.17.0.163 size 1475 Type escape sequence to abort. Sending 5, 1475-byte ICMP Echos to 2.17.0.163, timeout is 2 seconds: ..... Success rate is 0 percent (0/5) Router#
So i checked different IOS for this behavior:
c880data-universalk9-mz.157-3.M4a.bin: max 1474 Byte
c880data-universalk9-mz.156-3.M7.bin: max 1474 Byte
c880data-universalk9-mz.155-3.M10.bin: max 1492 Byte
Does anybody know why getting MTU issues starting with 15.6?
If someone has an idea please let me know to share more input.
Kind Regards
Dirk
01-26-2020 08:19 AM
- Could you check the (default) MTU values in the running config on the ATM and Dialer interfaces after the upgrade ? If they would be accidentally higher then reduce them again to the working values from the config before the upgrade. Check if this helps.
M.
01-26-2020 04:01 PM
the configured MTU after IOS-Upgrade are:
ATM0: 1600 Byte
Dialer1: 1492 Byte
It doesn't change when removing and adding again. We still get 1474 Byte only. So what happens with 18 Byte?
This starts with IOS 15.6.
Cheers
Dirk
01-29-2020 01:22 AM
Hi all (including Cisco TAC),
i have now tested a bit more between Software versions.
Last Image of tree 15.5: c880data-universalk9-mz.155-3.M10.bin
Everything works fine as expected, MTU of 1492 Byte are available.
Router#ping 2.17.0.163 size 1474 Type escape sequence to abort. Sending 5, 1474-byte ICMP Echos to 2.17.0.163, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 32/32/32 ms Router# Router#ping 2.17.0.163 size 1492 df-bit
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/30/32 ms
Router# Router#show run int atm0 | i mtu mtu 1600 Router# Router#show int atm0 | i MTU MTU 1600 bytes, sub MTU 1600, BW 2044 Kbit/sec, DLY 180 usec, Router# Router#show int dialer 1 | i MTU MTU 1492 bytes, BW 56 Kbit/sec, DLY 20000 usec, MTU 1492 bytes, BW 2044 Kbit/sec, DLY 20000 usec, Router# Router#show run int dialer 1 | i mtu mtu 1492 Router#
First Image of tree 15.6: c880data-universalk9-mz.156-3.M.bin
Max. MTU of 1474 available, no config changes done, same MTU values as with previous image.
Router#ping 2.17.0.163 size 1474 Type escape sequence to abort. Sending 5, 1474-byte ICMP Echos to 2.17.0.163, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 32/32/36 ms Router# Router#ping 2.17.0.163 size 1475 Type escape sequence to abort. Sending 5, 1475-byte ICMP Echos to 2.17.0.163, timeout is 2 seconds: ..... Success rate is 0 percent (0/5) Router# Router#show run int atm0 | i mtu mtu 1600 Router# Router#show int atm0 | i MTU MTU 1600 bytes, sub MTU 1600, BW 2044 Kbit/sec, DLY 180 usec, Router#
Looks like a bug for me, or a new unknown feature.
Cisco, please help.
Many thanks
Dirk
