Multi Area OSPF
Telim
Hi Guys, I'm trying to do the Multi-Area OSPF in 5 routers.
It the first time that I do that. So, I don't know what am I doing wrong can someone help me?
Thanks a lot in advance
Topology
Build the following network. (multi-area OSPF, VLANs)
5 Routers with serial ports
2 Switches (switch attached to the last router on each leg)
1 end device attached to each switch
Network Leg A:
  10.10.10.0/25; network host requirement is 100 devices
  VLAN 100
Network Leg B:
172.16.20.0/26; network host requirement is 50 devices
VLAN 200
Configure multi-area OSPF and ping successfully from Leg A to Leg B.
Enable to pin from Pc1 to Router 1, Pc 2 to Router 2 and between the routers but I CANNOT ping between the pcs that is what I need to do.
Deepak Kumar
Please find working lab but here I want to clear some points:
1. Router ID should not duplicate in the network.
2. This is dynamic routing so network commands must assign to the connected network only (on the same router).
3. OSPF supports Variable Length Subnet Masks (VLSM). So configuration must be the same as your network.
You need an updated version of packet tracer to open this file.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
5 Replies 5
the attached file loads with an error, meaning none of the devices can be opened, and no config can be read. Either post the file again, or post the full configs of all 5 routers...
I attached it again. Let me know if it works.
Same error again. Just post the configs...
Deepak Kumar
Deepak Kumar
Deepak Kumar,
Thank you so much for explaining me this and for your help.
I thought I deleted my other post.
