Multi E1/T1 cards - clock issue
nguyen
On a 2811 acting as gateways for CCM 4.1 I have 2 Wic cards for 2 E1, with following conf :
network-clock-participate wic 0
network-clock-participate wic 1
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
controller E1 0/1/0
framing NO-CRC4
clock source internal
interface Serial0/0/0:15
no ip address
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/1/0:15
no ip address
isdn bchan-number-order ascending
no cdp enable
First E1 is connected to Provider A
Second E1 is connected to provider B
First E1 has never a problem
Second E1 loses its sync with lots of erros whether loss of frame, line code violations and eventually goes down.
I contacted the ISP the link is ok.
I think I have a clock configuration issue. I tried internal or line for second E1 but it is ok during a few minutes and goes down after 2 minutes.
any help ?
mchin345
Level 6
Level 6
If slips are present on the E1 line, there is a clocking problem. The Customer Premises Equipment (CPE) will need to synchronize to the clocking from the E1 provider (telco). Complete the following steps to correct this problem: check that the clock source is derived from the network. In the show controller e1 EXEC command output, look for Clock Source is Line Primary.
I just had this "type" of problem on T1 cards, so I'm going to tell you how I fixed it and hopefully it will help you:
Put this in global config, but change as needed:
network-clock-select 1 T1 0/0/0
Under the controller that you want to get your timing from, put the following:
controller t1 0/0/0
clock source line primary
The difference between you and I is that I was getting timing from the same provider for three different WICs.
What the above does is tell the router that controller x is going to be the primary clocking mechanism for the other cards. Then the network-clock-select command is setting the t1 controller to be the primary clocking source for all other cards on the router.
I can't tell you how frustrated I was with fighting this, and I hope this helps your issue. I was seeing CRC, framing, input errors, and aborts before doing this.
And make sure you take of the "clock source internal" on your one controller.
HTH,
John
HTH, John *** Please rate all useful posts ***
