multicast drops
David Trocki
I am seeing currently seeing an issue where multicast traffic is not reaching client boxes at a particular location.  When I check the first router upstream from the client everything looks normal with the joins, but the multicast isn't getting that far.
(*, 239.1.1.1), 2d16h/00:02:53, RP 0.0.0.0, flags: DC
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    GigabitEthernet2/0, Forward/Sparse-Dense, 2d16h/00:00:00
IGMP Connected Group Membership
Group Address    Interface                Uptime    Expires   Last Reporter
239.1.1.1      GigabitEthernet0/0/0.605 2d16h     00:02:54  10.11.50.50
The traffic is getting dropped on the router upstream from the one shown above.  I can see they get dropped as "Other drops"...however, the OIF is not null, and there is no rate-limiting...so for what other reasons would they get dropped?
sh ip mroute 239.1.1.1:
(10.5.250.50, 239.1.1.1), 00:01:18/00:01:41, flags:
  Incoming interface: POS2/0, RPF nbr 192.168.1.9, Mroute
    GigabitEthernet6/0, Forward/Sparse-Dense, 00:01:18/00:00:00
sh ip mroute 239.1.1.1 count:
Group: 239.1.1.1, Source count: 1, Group pkt count: 0
  Source: 10.5.250.50/32, Forwarding: 0/0/0/0, Other: 2493/40/2453
Furthermore, when I send multicast from another source in the same subnet, to the same client box, it is succssful.
Group: 239.1.1.1, Source count: 2, Group pkt count: 3
  Source: 10.5.250.70/32, Forwarding: 3/1/32/0, Other: 4/1/0
  Source: 10.5.250.50/32, Forwarding: 0/0/0/0, Other: 3142/101/3041
One thing that I did notice is that the TTL is too low on the one that is dropping.  The application sending the multicast needs to bump the TTL up by 1.  However, I would not expect the traffic to get dropped on this router.  The traffic I think should get forwarded to the next router, where the TTL would then be 1, and get dropped there.  I'm going to bump up the TTL by 1 tonight, but was really just curious as to why it was being dropped like this.
0 Replies 0
