multicast group joins between PIM-SM domains
kjbarrass
Beginner
Beginner
when you have two PIM-SM domains peering with each other using MSDP, how does one PIM domain join a group in the other PIM domain it knows about via MSDP. Does it use IGMP between the domains or is this part of MSDP.
Kind Regards
Kev
Harold Ritter
PIM joins are used between the two domains just as they are within a single domain. IGMP is only used between the multicast receiver and its local router.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Harold Ritter
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Thanks for that is just what I needed Ive been reading the IETF internet draft and couldnt find anything in it about Joins.
Thanks for the reply.
