Join Customer Connection to register!
678
Highlighted
Participant
multicast mac on nexus
Hi to alle,
i have a couple of nexus 7010 (5(2)3a) connected to a checkpoint in HA(active/active)
I have now to configure multicast mac..i found this commmand:
interface vlan xx
ip arp <ip address VIP FW> <0100.5exx.xxxx>
vlan configuration xx
layer2 multicast lookup mac
then
mac address-table multicass <0100.5exx.xxxx> vlan xx interface e3/7
when i insert teh last coomand i get the following error:
invalid mac:0100.5exx.xxxx,ip based range
any idea about to solve this issue?
regards
Alessandro
1 REPLY 1
Highlighted
Hall of Fame Master
Hello Alessandro,
a possible solution (if supported on Checkpoint side)  is to map the FW VIP on a multicast MAC address that does not belong the the range for IPv4 multicast as explained in the following link.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080a07203.shtml#configs
any MAC with the last significant bit of most significant octet set to 1 is multicast for example
0300.5e11.1111.
Hope to help
Giuseppe
