Multicast mtrace question
sasif
Is there a way to get the name of the router i.e. the router prompt with the interface address in the output of the mtrace command instead of just the interface addresses.
R1#mtrace 1.1.1.1 2.2.2.2 239.1.1.1.
Mtrace from 1.1.1.1 to 2.2.2.2 via group 239.1.1.1
From source (?) to destination (?)
Querying full reverse path... * switching to hop-by-hop:
0 1.1.1.1
-1 * 1.1.17.1 PIM [1.1.1.1/32]
-2 * 1.12.1.13 PIM [1.1.1.1/32]
purohit_810
Level 5
Level 5
Did you try Mstat Command
mstat {source-name | source-address} [destination-name | destination-address] [group-name | group-address]
2) Once you do MTRACE after use PING and resolve it. If you would perticular hop name.
Dharmesh Puorhit
