Multicast routing
Cisconew
Below is my task to do. I have configured as per below network topology. Unicast routing is working from receiver to source and vice versa. But multicast routing is not working. I need to know the reasons for this and also the task question also.Please help me.
Task:
Only BGP is running on the routers. Each router is in its own ASN. Only the LAN networks (where servers are connected) and the loopback0 addresses are advertised via BGP using network statements. BGP synchronization is disabled. Transit networks are not advertised. There are no default networks. PIM sparse mode is configured on all interfaces and the RP is set to 3.3.3.3(Router 3) on all routers.
Router 3 is hitting 100% CPU utilization and dropping packets because of the high CPU. What could be causing this?
2 Accepted Solutions
Harold Ritter
Hi @Cisconew ,
Here's probably what is causing the high CPU on the RP (R3).
1. Multicast traffic coming from Source1 is received on R1
2. R1 encapsulates the multicast packets and send them to R3 (PIM register message with source 192.168.12.1) until it receives a PIM register stop message.
3. R3 receives the encapsulated packets from R1 and tries to send a PIM register stop message to 192.168.12.1, as this is the PIM register message source address.
4. R3 doesn't have a route to 192.168.12.1, as transit interfaces are not advertised in BGP and can't send the PIM register stop message to R1
5. it keeps receiving the PIM register messages and need to decapsulate lots of traffic, which is causing the high CPU.
Hi @Cisconew ,
There is two ways you can fix this issue.
1. use the command
ip pim register-source Loopback0
on R1. You also need to configure
ip pim sparse-mode on lo0
2. Inject the transit subnets in BGP.
I prefer option 1.
29 Replies 29
I need to See R1 and R4 config
Also
Show ip route
in R1 and R4
Please find below the configurations of R1 and R4
R1:
hostname R1
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip multicast-routing
ip cef
no ipv6 cef
redundancy
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface GigabitEthernet0/0
ip address 10.10.10.1 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip address 192.168.12.1 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
ip address 192.168.14.1 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
media-type rj45
router bgp 100
bgp router-id 1.1.1.1
bgp log-neighbor-changes
network 1.1.1.1 mask 255.255.255.255
network 10.10.10.0 mask 255.255.255.0
neighbor 192.168.12.2 remote-as 200
neighbor 192.168.14.4 remote-as 400
ip forward-protocol nd
no ip http server
no ip http secure-server
ip pim rp-address 3.3.3.3
ipv6 ioam timestamp
R4:
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
redundancy
interface Loopback0
ip address 4.4.4.4 255.255.255.255
ip address 10.100.100.4 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
media-type rj45
ip address 192.168.14.4 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/3
ip address 192.168.34.4 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
media-type rj45
router bgp 400
bgp router-id 4.4.4.4
network 4.4.4.4 mask 255.255.255.255
network 10.100.100.0 mask 255.255.255.0
neighbor 192.168.14.1 remote-as 100
neighbor 192.168.34.3 remote-as 300
no ip http server
ipv6 ioam timestamp
control-plane
Show ip route
in R1 and R4
And config of R3
Please find below the routing tables of R1 and R4
R1:
R1#sh ip route | b Gate
Gateway of last resort is not set
1.0.0.0/32 is subnetted, 1 subnets
C 1.1.1.1 is directly connected, Loopback0
2.0.0.0/32 is subnetted, 1 subnets
B 2.2.2.2 [20/0] via 192.168.12.2, 00:46:28
3.0.0.0/32 is subnetted, 1 subnets
B 3.3.3.3 [20/0] via 192.168.14.4, 00:46:29
4.0.0.0/32 is subnetted, 1 subnets
B 4.4.4.4 [20/0] via 192.168.14.4, 00:46:29
10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C 10.10.10.0/24 is directly connected, GigabitEthernet0/0
L 10.10.10.1/32 is directly connected, GigabitEthernet0/0
B 10.100.100.0/24 [20/0] via 192.168.14.4, 00:46:29
192.168.12.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.12.0/24 is directly connected, GigabitEthernet0/1
L 192.168.12.1/32 is directly connected, GigabitEthernet0/1
192.168.14.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.14.0/24 is directly connected, GigabitEthernet0/2
L 192.168.14.1/32 is directly connected, GigabitEthernet0/2
R4:
R4#sh ip route | b Gate
B 1.1.1.1 [20/0] via 192.168.14.1, 00:48:10
B 2.2.2.2 [20/0] via 192.168.14.1, 00:47:41
B 3.3.3.3 [20/0] via 192.168.34.3, 00:48:10
C 4.4.4.4 is directly connected, Loopback0
B 10.10.10.0/24 [20/0] via 192.168.14.1, 00:48:10
C 10.100.100.0/24 is directly connected, GigabitEthernet0/0
L 10.100.100.4/32 is directly connected, GigabitEthernet0/0
L 192.168.14.4/32 is directly connected, GigabitEthernet0/2
192.168.34.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.34.0/24 is directly connected, GigabitEthernet0/3
L 192.168.34.4/32 is directly connected, GigabitEthernet0/3
the BGP make path for R1 via R4 to reach R3.
that I think issue here,
you need to Make R1 path not via R4
the simple solution is
router bgp R1
neighbor R4 route-map MHM in
route-map MHM permit 10
set weight 100
Hi @MHM Cisco World ,
I am not sure why this would be an issue. PIM register messages would still be able to get from R1 to R3. The issue that I explained before would still apply as R1 would send PIM register with a source of 192.168.14.1 and R3 does not know how to reach that address, as transit subnets are not advertised in BGP. Using
on R1 would fix this issue.
Reciver's configuration;
Receiver#sh run int g 0/0
Building configuration...
Current configuration : 168 bytes
ip address 10.100.100.10 255.255.255.0
ip pim sparse-mode
ip igmp join-group 229.7.7.7
duplex auto
speed auto
media-type rj45
end
Ping is successful from Source to receiver
Receiver#ping 10.10.10.10
Sending 5, 100-byte ICMP Echos to 10.10.10.10, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 5/6/9 ms
Receiver#trace 10.10.10.10 num
Tracing the route to 10.10.10.10
VRF info: (vrf in name/id, vrf out name/id)
1 10.100.100.4 2 msec 2 msec 2 msec
2 192.168.14.1 5 msec 3 msec 4 msec
3 10.10.10.10 4 msec * 4 msec
Receiver#mtrace 10.10.10.10
Mtrace from 10.10.10.10 to 10.100.100.10 via RPF
From source (?) to destination (?)
Querying full reverse path...
0 10.100.100.10
-1 10.100.100.10 ==> 10.100.100.10 PIM/Static [default]
-2 10.100.100.4 ==> 192.168.14.4 PIM/MBGP [10.10.10.0/24]
-3 192.168.14.1 ==> 10.10.10.1 PIM_MT [10.10.10.0/24]
-4 10.10.10.10
Check my comment above'
You need to change path of R1 to R3.
Do this and check again.
Source Configuration:
Source#ping 10.100.100.10
Sending 5, 100-byte ICMP Echos to 10.100.100.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/5/6 ms
Source#trace 10.100.100.10
Tracing the route to 10.100.100.10
1 10.10.10.1 2 msec 2 msec 2 msec
2 192.168.14.4 4 msec 4 msec 4 msec
3 10.100.100.10 5 msec 5 msec *
Source#mtrace 10.100.100.10
Mtrace from 10.100.100.10 to 10.10.10.10 via RPF
*Jul 13 16:22:18.816: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=E039BE0, count=0
-Traceback= 2222FEz 1C89541z 1C834ADz* switching to hop-by-hop:
0 10.10.10.10
-1
*Jul 13 16:22:30.825: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=E03B4B8, count=0
*Jul 13 16:22:33.824: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=E03A0D8, count=0
*Jul 13 16:22:36.823: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=E03D780, count=0
-Traceback= 2222FEz 1C89541z 1C834ADz* Timed out receiving responses
Perhaps no local router has a route for source, the receiver is not
a member of the multicast group or the multicast ttl is too low.
Source#ping 229.7.7.7 repeat 10000
Sending 10000, 100-byte ICMP Echos to 229.7.7.7, timeout is 2 seconds:
Hi @Cisconew ,
To fix the issue of not being able to ping the receiver, you need to remove all the multicast configuration from the receiver, except
and reload the receiver.
Full configuration of Receiver:
Receiver#sh run
Current configuration : 3026 bytes
version 15.7
hostname Receiver
no mmi pvc
ip cef
no ipv6 cef
redundancy
ip pim sparse-mode
duplex auto
speed auto
media-type rj45
ip default-gateway 10.100.100.4
no ip http server
ip route 0.0.0.0 0.0.0.0 10.100.100.4
ipv6 ioam timestamp
Hi @Cisconew ,
As mentioned in my previous post, the receiver should be configured as a host, not a multicast router.
You need to do the following:
no ip routing
no ip multicast-routing
int gi0/0
no ip pim sparse-mode
It should work after.
Do you think I should remove these configurations on Source host too?.Here I have given
rp address
command too.
Source#sh run
hostname Source
no ip routing
no ip cef
no ipv6 cef
ip address 10.10.10.10 255.255.255.0
ip pim sparse-mode
no ip route-cache
duplex auto
speed auto
media-type rj45
ip default-gateway 10.10.10.1
no ip http server
Hi @Cisconew ,
The source doesn't need any multicast configuration whatsoever. So you can remove all of it.
no ip routing
int gi0/0
no ip pim rp-address 3.3.3.3
