Multilink PPP over ATM problem
I am trying to configure a multilink ppp over ATM links.
I have 2 pvc 20 Mb each (1 microwaves 1 optical fiber)
I have been following the documentation but I still having problems
I get the following error:.May 2 20:57:19: %ATM-3-MLPOATM_ERROR: MLPoATM not configured properly on
Link Virtual-Access2 Bundle Multilink11 :dLFI
May 2 20:57:19: SP: ltl operation not ok for vlan 1033 and index -1
.May 2 20:57:23: %ATM-3-MLPOATM_ERROR: MLPoATM not configured properly on
May 2 20:57:23: SP: ltl operation not ok for vlan 1034 and index -1
My config on each interface is as follow:
interface ATM12/0/0.78 point-to-point
pvc 0/78
abr 20000 20000
encapsulation aal5snap
protocol ppp Virtual-Template1
interface Virtual-Template1
bandwidth 20000
no ip address
load-interval 30
ppp authentication chap
ppp multilink
ppp multilink group 11
service-policy output QoS_PLC_STM_77
end
interface Multilink11
ip address 200.1.147.161 255.255.255.252
ppp multilink
ppp multilink fragment delay 20
ppp multilink interleave
end
I will really appreciate your help. any suggestion?
LP
mounir.mohamed
Level 7
Level 7
Could you provide me with *Show version* / *show policy-map* of this box, Cisco relate this message to alot of code bugs or incorrect or incomplete MLPoATm configurations in many documents.
http://www.ciscopowerednetworks.com/univercd/cc/td/doc/product/software/ios124/124sup/124sms/124smsv1/sm_02h.pdf
Example:
cosmetic bug (CSCdz87121) on Cisco 1721 running 12.2(x) code
Hi Mounir, I attache the sh-running. Here is the show policy-map
policy-map QoS_PLC_STM_77
description QoS_Hacia_SanTome_PVC77 (BW Avail = 22 Mbps)
class Notes
police 16000000 conform-action set-dscp-transmit af41 exceed-action set-dscp-
transmit af43 violate-action drop
class Navegar
police 3000000 conform-action set-dscp-transmit af11 exceed-action set-dscp-t
ransmit af13 violate-action drop
class Aplic_Corporativas
police 1000000 conform-action set-dscp-transmit af31 exceed-action set-dscp-t
ransmit af33 violate-action drop
class Windows
police 2000000 conform-action set-dscp-transmit af21 exceed-action set-dscp-t
ransmit af23 violate-action drop
class class-default
fair-queue
random-detect dscp-based
Thanks for your time
