Multilink Vsat
Tony MALPASS
I have a vsat connection with 2 E1's in a multilink. Does it matter that they are showing different clock sources.?
one is showing as Internal and the other is showing as Line.
handoko wiyanto
Level 3
Level 3
hi,
do you have problems (such as alarm) with those E1 connection?
or you notice some errors in show interface, show controllers?
as per my understanding, the router interface and telco device need to agree on this clock so that they can create the E1 frame, otherwise you can have Layer 1 E1 link problems.
regards,
