Multipath Routing - EIGRP
sstringham
I have a routing question.
Previous configuration:
3620 with 2 T1 lines to a 3640 (in the central office). I would do a show ip route and both lines would show up for the subnet in either router.
New configuration:
3620 with 3 t1 cards. (two are the same - 1 new). But, the new one is going to a 2821 at another location. Between that 2821 and the 3640 is a 6506 (sup 720) and a 4506 (sup iv). The 3640 sees all three routes. The 6506 (directly connected to the 2821) sees only the route through the 2821, and the 4506 only sees the one through the 3640. The 2821 only lists the one through it's t1 to the 3620. All routing is EIGRP.
Any ideas on where to look?
6 Replies 6
Roberto Salazar
Level 8
Level 8
It's pretty hard to follow, let's start with maybe you can provide a simple ascii topology drawing and the show ip route for all the routers involved.
you need to look at 4506 and 6509 switch wherther EIGRP routing is available there or not.and what is the connectivity between 3640---4506----6509----2811 devices as bosalaza suggested show output will definitly be a good way of troubleshooting and finding the problem.
Ok.
We have a 3620 in a remote office. This has two T1 connections to the 3640 in the main office. Also one T1 to the 2821.
We have in the main office a 3640 with two T1 connections to the 3620. It also is connected to the 4506 via a 100mb enet.
The 4506 is connected to the 6506 via a 100mb trunk.
The 6506 is at a new offsite data center with the 2821.
The 2821 is connected to the 6506 with GigE, and to the 3620 via T1.
3620 ----- Local network
T1 / / \
/ / T1 \ T1 (New)
3640 - 4560 - 6506 - 2821
100 100T Gig
3620 Example
interface Serial1/0
ip address 172.16.99.202 255.255.255.252
ip load-sharing per-packet
ip route-cache flow
The 4506 and 6506 IPs are bound to the VLAN.
interface Serial0/1/0
ip address 172.16.99.221 255.255.255.252
ip route-cache flow
no ip mroute-cache
This is on all devices
router eigrp 44050
variance 2
redistribute static
network 172.16.0.0
no auto-summary
no eigrp log-neighbor-changes
3620 Routing Table (truncated)
C 172.16.97.0/24 is directly connected, Ethernet1/0 ---- Local Subnet
D 172.16.100.0/23 [90/3181312] via 172.16.99.201, 15:55:39, Serial1/0
[90/3181312] via 172.16.99.205, 15:55:39, Serial1/1
[90/2170368] via 172.16.99.221, 15:55:39, Serial0/0 --- NEW
D 172.16.104.0/24 [90/3181568] via 172.16.99.201, 16:05:05, Serial1/0
[90/3181568] via 172.16.99.205, 16:05:05, Serial1/1
[90/2170368] via 172.16.99.221, 16:05:06, Serial0/0
C 172.16.99.200/30 is directly connected, Serial1/0
C 172.16.99.204/30 is directly connected, Serial1/1
C 172.16.99.220/30 is directly connected, Serial0/0
2821 Routing Table (truncated)
D 172.16.97.0/24 [90/2195456] via 172.16.99.222, 15:56:09, Serial0/1/0 --- New
D 172.16.99.0/27 [90/3328] via 172.16.99.237, 15:56:09, GigabitEthernet0/0
D 172.16.100.0/23
[90/3072] via 172.16.99.237, 15:56:09, GigabitEthernet0/0
D 172.16.99.200/30
[90/3179264] via 172.16.99.237, 16:05:40, GigabitEthernet0/0
[90/3690496] via 172.16.99.222, 16:05:40, Serial0/1/0
C 172.16.99.220/30 is directly connected, Serial0/1/0
C 172.16.99.236/30 is directly connected, GigabitEthernet0/0
3640 Routing Table (truncated)
D 172.16.97.0/24 [90/3204096] via 172.16.99.206, 15:57:15, Serial1/1
[90/3204096] via 172.16.99.202, 15:57:15, Serial1/0
[90/2198528] via 172.16.99.233, 15:57:15, FastEthernet0/0 --- New
D 172.16.99.0/27 [90/28416] via 172.16.99.233, 15:57:15, FastEthernet0/0
D 172.16.100.0/23 [90/28416] via 172.16.99.233, 15:57:15, FastEthernet0/0
C 172.16.99.232/30 is directly connected, FastEthernet0/0
D 172.16.104.0/24 [90/28672] via 172.16.99.233, 16:17:19, FastEthernet0/0
4506 Table (truncated)
D 172.16.97.0/24 [90/2195968] via 172.16.100.3, 15:58:41, Vlan1 --- Target Subnet
C 172.16.100.0/23 is directly connected, Vlan1
D 172.16.104.0/24 [90/3072] via 172.16.100.3, 1w0d, Vlan1
C 172.16.99.232/30 is directly connected, Vlan16
D 172.16.99.236/30 [90/3072] via 172.16.100.3, 1w0d, Vlan1
D 172.16.99.220/30 [90/2170368] via 172.16.100.3, 15:58:42, Vlan1 --- New
D 172.16.99.200/30 [90/3178752] via 172.16.99.234, 3d11h, Vlan16
6506 Table (truncated)
D 172.16.97.0/24 [90/2195712] via 172.16.99.238, 16:00:18, Vlan18 --- Target Subnet
D 172.16.99.0/27 [90/3072] via 172.16.100.1, 1w0d, Vlan1
C 172.16.104.0/24 is directly connected, Vlan30
D 172.16.99.232/30 [90/3072] via 172.16.100.1, 1w0d, Vlan1
C 172.16.99.236/30 is directly connected, Vlan18
D 172.16.99.220/30 [90/2170112] via 172.16.99.238, 16:00:22, Vlan18
D 172.16.99.200/30 [90/3179008] via 172.16.100.1, 3d11h, Vlan1
D 172.16.99.204/30 [90/3179008] via 172.16.100.1, 3d11h, Vlan1
Anything else to help?
Maybe, show ip eigrp topo from both the 4506 and 6506.
