Multiple concurrent PPPOE connections ?
HDBank Network
I'm configuring load balance over multiple pppoe connections. The pppoe connections're UP when I show pppoe session, here's pppoe configuration:
interface FastEthernet0/2/0
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface FastEthernet0/2/1
no ip address
duplex auto
speed auto
pppoe-client dial-pool-number 2
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip tcp adjust-mss 1000
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username ******** password *******
interface Dialer2
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
then I config NAT & default route, PCs can connect to the Internet
ip route 0.0.0.0 0.0.0.0 Dialer1
ip nat inside source route-map CMC-NAT interface Dialer2 overload
ip nat inside source route-map VNPT-NAT interface Dialer1 overload
The problem is that I cannot ping from source interface Dialer2. Conversely, when I config default route over Dialer2, I cannot ping from source interface Dialer1. Therefore, I cannot monitor pppoe connections concurrently through IP SLAs.
Please help me
can you try config below;
interface FastEthernet0/0
ip policy route-map LOADBALANCE
ip route 8.8.8.8 255.255.255.255 Dialer2
ip route 8.8.4.4 255.255.255.255 Dialer1
ip sla 1
icmp-echo 8.8.8.8 source-interface Dialer2
timeout 2000
threshold 1000
frequency 5
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 8.8.4.4 source-interface Dialer1
timeout 2000
threshold 1000
frequency 5
ip sla schedule 2 life forever start-time now
route-map CMC-NAT permit 10
match ip address wireless
route-map VNPT-NAT permit 10
no ip route 0.0.0.0 0.0.0.0 Dialer1
no ip route 0.0.0.0 0.0.0.0 Dialer2
hth
Muammer
7 Replies 7
mrdogantr
     Can you try double default route.
hth
Muammer
I tried the double default route, but I always can ping only from source Dialer2.
     Did you try when dialer2 is shutdown. Can you share your config file.
When I use double default routes, I can ping only from source Dialer2. When I shutdown Dialer2, I can ping from source Dialer1 (still using double default route). Then, when I up Dialer2, I can ping only from source Dialer1.
ip sla 1
timeout 2000
threshold 1000
frequency 5
ip sla 2
timeout 2000
threshold 1000
frequency 5
hth
Muammer
yeah, it works. Thank you very much, Muammer.
Nice weekend
     Please rate the helpful posts.
Muammer
