02-11-2011 01:26 PM - edited 03-04-2019 11:23 AM
We are adding a new remote office to our MPLS cloud. Their LAN subnet happens to have the same IP scheme as one of our other offices. Changing the IP scheme is not an option.
Is it possible to do outbound (from remote office to headend), and translate to an IP not local to the remote router? Essentially NAT to a random IP? From our head end, we would need to connect to a couple devices, so we would like to do static NAT from out to in (not in config below).
Would the following config work?
int fa0/0
ip address 192.168.10.1 255.255.255.0
ip nat inside
int s0/0 (head-end facing interface)
ip address X.X.X.X 255.255.255.252
ip nat outside
no shut
ip route 0.0.0.0 0.0.0.0 X.X.X.Y (all non-local traffic goes to head-end)
ip nat inside source list NAT_OUT pool NAT_OUT_POOL overload
ip access-list extended NAT_OUT
permit ip 192.168.10.0 0.0.0.255 any
ip nat pool NAT_OUT_POOL 172.16.99.99 172.16.99.99 netmask 255.255.255.255
Solved! Go to Solution.
02-12-2011 10:53 AM
To be able to connect back to devices the easiest way is to perform network nat.
So you have a remote site with 192.168.10.0/24 and you are already using that, then choose a subnet that is free. And you want 172.16.99.0/24
int fa 0/0
ip nat inside
int s0/0
ip nat outside
ip nat inside source static network 192.168.10.0 172.16.99.0 /24
This way you know that any static IP address machines will match = 192.168.10.23 <> 172.16.99.23 etc.
HTH>
02-12-2011 10:53 AM
int fa 0/0
ip nat inside
int s0/0
ip nat outside
HTH>
