Multiple networks
Student HoGent
Hey, i am student. And for a school project we have to make a network for a company.
I don't really now how to start this project.
Case study
The newly purchased building consists of a reception department and an administration department + management. After consultation with management, the IT architect designed the following design. After a few minor adjustments, our technical department installed the hardware devices below. These now need to be fully configured.
Firt Floor:
Wired lan: 192.229.x.x/16
Wireless Lan Controller: on this device we create 3 Vlans for the networks below.
1. 802.11 visitors 192.229.x.x/24
2. 802.11 employees 192.229.x.x/24
3. 802.11 management 192.229.x.x/28
Printer First Floor has a fixed IP
Private AP 192.168.0.0/30 SSID should NOT be visible.
Reception:
Wired lan: 172.77.x.x//16
Wireless Lan Controller: on this device we create 4 Vlans for the networks below.
1. 802.11 visitors 172.77.x.x/24
2. 802.11 employees 172.77.x.x/24
3. 802.11 management 172.77.x.x/28
4. 802.11 Sales 172.77.x.x/28
Printer reception has a fixed IP
The 2 department routers use EIGRP and are connected to the ISP via default route
All PCs and laptops use DHCP.
6 Replies 6
matthew2587
I would just start with the DHCP on the routers (excluding printer addresses) to make sure everything wired can talk. Then I would move onto wireless.
Thx for the fast response, I did the DHCP on the routers and everything is working correctly. But I don't know if the IP ranges i used are correct.
For the wired LAN is used 192.229.0.0/24 for First Floor and 172.77.0.0/24 for Reception.
As long as you have routing between the two LANs I don't see an issue.
And how would you do the Wireless LAN networks?
I thought:
First Floor:
Wired LAN: 192.229.0.0 /24 (This is already done in my packet tracer)
Wireless LAN:
Guest: 192.229.1.0 /24
Employees: 192.229.2.0 /24
Management: 192.229.3.0 /28
Reception:
Wired LAN: 172.77.0.0/24 (This is already done in my packet tracer)
Wireless LAN:
visitors 172.77.1.0/24
employees 172.77.2.0/24
management 172.77.3.0/28
Sales 172.77.3.16/28
But i don't know if this is correct.
Once again, the IP addresses look fine to me, everything just needs to be set up properly. Like making a VLAN for each wireless LAN, and possibly adding ACLs to prevent the visitors access.
Student HoGent
@Flavio Miranda can you help me with this problem?
