05-28-2008 06:28 PM - edited 03-03-2019 10:08 PM
hello...
can anyone discuss the disadvantages and advantages of multiple providers to MPLS VPN? thanks... :D
Solved! Go to Solution.
05-28-2008 09:27 PM
the major advantage is that the redundacy and the major disadvantage is that anyone can spoof the vpn routes. Because when the packet will come to the asbr routers it will only look forward for the next hop label and never look for the vpn label which is in the stack and that label may be facked in that case. Another dis. is the improper route advertisements.
regards
shivlu
05-28-2008 09:27 PM
regards
shivlu
