Multiple Site VPN with EIGRP
I am curious for the best way to approach configuring 4 sites each connected to 2 fully meshed WAN networks (each net delivered as ethernet to the site's gateway router) with all site-to-site traffic being sent over a VPN/IPsec tunnel with EIGRP routing determining best path/failover?
I am trying to avoid creating 6 point-to-point tunnels on each site's router (site A net 1 = A1<>B1, A1<>C1, A1<>D1 / site A net 2 = A2<>B2, A2<>C2, A2<>D2).  Without encryption, the setup is easy because each ethernet interface is a "private LAN" so establish EIGRP routing, setup neighbors, and you are good to go.  Is there a way to add encryption without having to hardcode each VPN tunnel and use EIGRP for best path?
typically, and in order to avoid having to build multiple static tunnels, DMVPN would be the solution, not sure if you have looked into this already ?
Thank you for your response!
I had looked at that initially, but doesn't that still require a "hub / spoke" type connection?  In other words, I have 4 sites and in DMVPN, I would have to configure a "hub" site, correct?   Let's call that site A.   Behind the scene, it is my understanding that if Site B wants to communicate with Site C, it actually does so via Site A (a transparent type bridge).   In other words, if the hub goes down, none of the spokes can communicate with each other.   So in this case, if Site A were to fail (or loose connection to the WAN network), Site B would not be able to communicate with Site C.  Do you know if this is correct when using DMVPN?
You are exactly right. DMVPN is a hub/spoke setup. You could configure dual hubs though. The only other way I see (and one that doesn't require multiple tunnels on all routers) is an ISP provided MPLS solution.
I was looking at DMVPN a bit closer and I see a reference to a Phase 1, Phase 2, and Phase 3.  The impression I am getting is that a "Phase 2" and "Phase 3" solution addresses this "Hub/Spoke" failure issue.  Though I can't seem to find information confirming this.
Here is a site I was looking at about the Phases.  I am assuming this is really "versions of DMVPN" on not actual phases of DMVPN link creation on the routers.
https://learningnetwork.cisco.com/blogs/vip-perspectives/2017/02/15/dmvpn-the-phases-in-depth
