Multiple vlan on a single port not trunk
  Hi, need some help.
Valn 10: PC
Vlan 30: voice
Vlan 40: printer
How can I configure a single port for multiple vlans?? I am using a Cisco 3560 G PoE as an access switch. Vlans have differrent subnets.
I have a trunk on my last port:
interface gi0/24
switchport mode trunk
switchport trunk allowed vlan 10, 30, 40
On my port:
interface gi0/1
description LAN Access
switchport access vlan 10
switchport voice vlan 30
spanning-tree portfast
How can my printers have connection on that port???
regards rey
2 Accepted Solutions
cadet alain
to my best knowledge they can't  as this type of "mini trunk" port only supports 1 tagged vlan which is the data in your case. you need a real trunk port to have multiple tagged frames.
Regards.
Alain
Giuseppe Larosa
Hello Reymond,
you cannot achieve a "plug and play" configuration involving three Vlans.
There is no 3-vlans capable mini Vlan and a printer cannot be distinguished from a PC when it starts to connect to the network ( it will try to get an IP address via DHCP or it can have a manually configured IP address exactly like a PC) it does not use special protocol messages.
On ports where you know a printer will be connected you will need
switchport access vlan 40
instead of
This means that any time a new printer has to be connected to the network a specific network side configuration is needed.
You can use the description command to label the interfaces connecting to printers.
Hope to help
Giuseppe
cadet alain
Regards.
Alain
Giuseppe Larosa
Hello Reymond,
instead of
Hope to help
Giuseppe
Thanks for the quick response.
That help a lot.
Rey
