Multipoint with dissimilar links.
dandreatta
Here is the scenario:
I have to locations connected via a T3 with a VPN/GRE tunnel for backup. If the T3 fails traffic is re-routed almost transparently across the VPN tunnel with the exception of Citrix traffic. Because of the few seconds it takes for the traffic to re-route, Citrix users almost always get disconnected.
My question is; is it possible to create a multipoint group with the T3 and the VPN tunnel but have traffic only cross the T3 unless the T3 goes down? My thinking is that all of my routes between these 2 locations would come from the multipoint interface and would take less time to re-route the traffic to the VPN tunnel.
spremkumar
Level 9
Level 9
Do you have any kinda delay configured in any of these links ?
BTW can u post out your config out here also revert back over which physical media you are forming your VPN/GRE Tunnel ?
regds
nkumar2005
please tell how is the switchover taking place
are you using dynamic routing protocal like EIGRP, OSPF or have you defined any other method for backup line backup-interface etc
