N9K MAC Learning issue
amit.fernandes
We recently installed new ToR N9K switches replace our EOL Catalyst 4948s.
Some of the clients on this device could not connect to the network post an OS upgrade & reboot of the clients.
The N9K port shows up/up but could not see the client MAC. We moved it to an adjacent port. The MAC was learned immediately  and the client was back on the network.
The switches are N9K-C93108TC-EX with 48 100M/1G/10G port and 7.0(3)I4(3).
Anyone with similar issues ?
Thanks.
Francesco Molino
You're probably facing three bug https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvc14970/?rfs=iqvred.
I don't see yet any fixed release.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Sergiu.Daniluk
Hi @amit.fernandes
As @Francesco Molino  mentioned, looks like CSCvc14970 is affecting you.
Note that:
Conditions:
N9K-C93108TC-EX running 7.0(3)I4(2) or 7.0(3)I4(3)
Upgrade to a more mature version to fix the defect. You can check this link for current and upcoming recommended releases:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/recommended_release/b_Minimum_and_Recommended_Cisco_NX-OS_Releases_for_Cisco_Nexus_9000_Series_Switches.html
Also, before performing the upgrade, I strongly advise you to read the release notes and upgrade guides for the target NXOS image. Here are the repositories with all guides:
Upgrade guides: https://www.cisco.com/c/en/us/support/switches/nexus-9000-series-switches/products-installation-guides-list.html
Release notes: https://www.cisco.com/c/en/us/support/switches/nexus-9000-series-switches/products-release-notes-list.html
Sergiu
This seems to be the issue with code, as you bought a new device the cisco might have shipped with default NXoS and its recommended to upgrade the device to below version
We have faced similar issues and it got fixed after upgrade.
Cisco Nexus 9000 Series switches
7.0(3)I7(8)
Please do not hesitate to click the STAR button if you are satisfied with my answer.
