NAT and Port Forwarding
rocampo
Question.
Can a router do port forwarding using the IP on
its interface ?
Setup.
Internet ---- Router ----- Mail Server ( Private IP )
ISP gave only 1 global IP address which was already used on the router interface. I have
a mail server that needs to be seen outside and
other workstations that need internet access.
mhussein
Level 4
Level 4
This is possible, using NAT port forwarding with the extendable keyword. For example, port tcp 25 (smtp) can be forwarded/translated as follows:
ip nat inside source static tcp 25 25 extendable
This configuration example may be helpful:
http://www.cisco.com/warp/public/794/827spat.html
HTH,
Mustafa
