NAT for server
speedy2003
sorry for my english. I have one question. I have one server (web application) with IP 10.1.1.2 . It's located in the internal network. But on the router "newROUTER" is deployed NAT 10.1.1.2 to global address 83.15.52.165 (dns entry: app.example.com) , thus is accessible from the Internet.
If I want to open app.example.com address from inside the network is not available. If you enter the IP address 10.1.1.2 is the applications available. When I open the address app.example.com from another network or the Internet, app.example.com is available. I need advice on how to make address 83.15.52.165 (app.example.com) , that it was available on the internal network.
Topology:
INTERNET -------- [newPORTAL router] --------- [newROUTER router] ---------- [switch] ------ [switch] -------  [server 10.1.1.2]
Part of configuration is attached
Thanks in advance
--------------------------newPORTAL -----------------------------------------------------------------------
interface Tunnel1
ip address 172.16.0.1 255.255.255.252
ip nat outside
ip virtual-reassembly
tunnel source Vlan11
tunnel destination 192.168.254.1
interface FastEthernet0
description $ETH-LAN$
ip address 83.15.37.199 255.255.255.240
ip access-group INTERNET in
ip access-group SPY out
no ip redirects
ip accounting output-packets
ip nat outside
ip inspect FWOUT out
duplex auto
speed auto
no cdp enable
interface FastEthernet1
switchport access vlan 11
no ip address
interface FastEthernet2
switchport access vlan 4
no ip address
shutdown
interface FastEthernet3
no ip address
interface FastEthernet4
switchport access vlan 10
no ip address
no cdp enable
interface Vlan1
no ip address
interface Vlan4
no ip address
ip nat outside
shutdown
interface Vlan11
ip address 83.15.52.161 255.255.255.248
ip classless
ip route 0.0.0.0 0.0.0.0 83.15.37.193
ip route 10.2.0.0 255.255.255.0 Tunnel3
ip route 10.2.1.0 255.255.255.0 Tunnel4
ip route 83.15.52.163 255.255.255.255 83.15.52.166
ip route 83.15.52.170 255.255.255.255 Vlan11
ip route 83.15.52.171 255.255.255.255 83.15.52.166
ip route 83.15.52.172 255.255.255.255 83.15.52.166
ip route 83.15.52.173 255.255.255.255 83.15.52.166
ip route 83.15.52.174 255.255.255.255 Vlan11
ip route 83.15.52.175 255.255.255.255 83.15.52.166
ip route 83.15.52.176 255.255.255.255 83.15.52.166
ip route 83.15.52.177 255.255.255.255 83.15.52.166
ip route 83.15.52.179 255.255.255.255 Vlan11
ip route 83.15.52.184 255.255.255.255 83.15.52.166
ip route 192.168.254.1 255.255.255.255 83.15.52.166
ip nat pool ipool 83.15.52.161 83.15.52.161 netmask 255.255.255.248
ip nat inside source route-map MAP-DEF pool ipool overload
ip nat inside source static 10.10.1.2 83.15.52.164
ip access-list extended INTERNET
permit ip any host 83.15.37.199
permit ip any host 83.15.52.174
permit ip any host 83.15.52.161
permit ip any host 83.15.52.163
permit ip any host 83.15.52.166
permit ip any host 83.15.52.170
permit ip any host 83.15.52.172
permit ip any host 83.15.52.183
permit ip any host 83.15.52.175
permit ip any host 83.15.52.177
permit ip any host 83.15.52.179
permit ip any host 83.15.52.181
permit tcp any host 83.15.52.162 eq www
permit tcp any host 83.15.52.162 eq 443
permit tcp any host 83.15.52.162 eq pop3
permit tcp any host 83.15.52.162 eq smtp
permit tcp any host 83.15.52.162 eq 465
permit tcp any host 83.15.52.162 eq 585
permit tcp any host 83.15.52.162 eq 993
permit tcp any host 83.15.52.162 eq 995
permit tcp any host 83.15.52.162 eq 8443
permit tcp any eq smtp host 83.15.52.162
permit tcp any eq www host 83.15.52.162
permit tcp any eq 443 host 83.15.52.162
permit tcp any host 83.15.52.165 eq www
permit tcp any host 83.15.52.165 eq 443
permit tcp any host 83.15.52.165 eq 943
permit tcp any host 83.15.52.165 eq 4502
permit tcp any host 83.15.52.165 eq 4503
permit tcp any host 83.15.52.165 eq 4510
permit tcp any host 83.15.52.165 eq 14510
permit tcp host 176.61.240.48 eq 10001 host 83.15.52.165
permit tcp any host 83.15.52.164 eq www
permit tcp any host 83.15.52.164 eq 443
permit tcp any host 83.15.52.164 eq smtp
permit tcp any host 83.15.52.164 eq 143
permit tcp any host 83.15.52.164 eq 4503
permit tcp any host 83.15.52.164 eq 4504
permit tcp any host 83.15.52.164 eq 4505
permit tcp any host 83.15.52.164 eq 4506
permit tcp any host 83.15.52.164 eq 4507
permit tcp any host 83.15.52.164 eq 4508
permit tcp any host 83.15.52.164 eq 4509
permit tcp any host 83.15.52.164 eq 4510
permit tcp any host 83.15.52.164 eq 4511
permit tcp any host 83.15.52.164 eq 4512
permit tcp any host 83.15.52.164 eq 4513
permit tcp any host 83.15.52.164 eq 4514
permit tcp any host 83.15.52.164 eq 4515
permit tcp any host 83.15.52.164 eq 4516
permit tcp any host 83.15.52.164 eq 4517
permit tcp any host 83.15.52.164 eq 4518
permit tcp any host 83.15.52.164 eq 4519
permit tcp any host 83.15.52.164 eq 4520
permit tcp any host 83.15.52.164 eq 4521
permit tcp any host 83.15.52.164 eq 4522
permit tcp any host 83.15.52.164 eq 4523
permit tcp any host 83.15.52.164 eq 4524
permit tcp any host 83.15.52.164 eq 4525
permit tcp any host 83.15.52.164 eq 4526
permit tcp any host 83.15.52.164 eq 4527
permit tcp any host 83.15.52.164 eq 4528
permit tcp any host 83.15.52.164 eq 4529
permit tcp any host 83.15.52.164 eq 4530
permit tcp any host 83.15.52.164 eq 4531
permit tcp any host 83.15.52.164 eq 4532
permit tcp any host 83.15.52.164 eq 943
permit tcp host 176.116.107.3 host 83.15.52.164
permit tcp host 217.119.123.21 host 83.15.52.164 eq 1433
permit tcp host 217.12.59.25 host 83.15.52.164
permit tcp host 176.116.107.43 host 83.15.52.164
permit tcp host 85.159.105.246 host 83.15.52.164
evaluate INTERNET_OUT
deny   ip any any
deny   ip any any log
ip access-list extended SPY
permit ip host 83.15.52.162 host 195.28.64.119
permit ip host 83.15.52.162 host 81.89.56.95
permit ip host 83.15.52.162 any reflect INTERNET_OUT
permit ip any any
no logging trap
access-list 1 remark BEGIN CONFIG ACCESS
access-list 1 permit 83.168.174.164 log
access-list 1 permit 192.168.0.0 0.0.255.255 log
access-list 1 deny   any log
access-list 1 remark END CONFIG ACCESS
access-list 102 deny   ip any 10.2.0.0 0.0.255.255
access-list 102 permit ip 10.10.0.0 0.0.255.255 any
access-list 103 permit ip any 10.2.0.0 0.0.255.255
access-list 181 permit udp any eq domain any log
access-list 181 permit udp any any eq domain log
cdp timer 120
cdp holdtime 240
route-map MAP-DEF permit 20
match ip address 102
match interface FastEthernet0
----------------------------- newROUTER ------------------------------------------------
interface Loopback1
no ip address
interface Tunnel3
ip address 172.16.0.2 255.255.255.252
ip nat outside
ip virtual-reassembly in
tunnel source Vlan1
tunnel destination 83.15.52.161
interface GigabitEthernet0/1/0
switchport mode trunk
no ip address
interface GigabitEthernet0/1/1
no ip address
interface GigabitEthernet0/1/2
switchport access vlan 3
no ip address
interface Vlan1
ip address 192.168.254.1 255.255.255.0
ip nat inside
interface Vlan4
ip address 10.1.1.1 255.255.0.0
ip access-group vlan4_acl_in in
ip access-group vlan_acl_out out
ip nat inside
interface Vlan11
ip address 83.15.52.166 255.255.255.248
ip nat outside
ip local pool VLAN4VPN-POOL 10.1.1.128 10.1.1.254
ip local pool VLAN1VPN-POOL 192.168.250.2 192.168.250.255
ip local pool VPN-POOL 192.168.254.240 192.168.254.253
ip forward-protocol nd
ip nat inside source static 192.168.254.2 83.15.52.162
ip nat inside source static 10.1.1.2 83.15.52.165
ip route 0.0.0.0 0.0.0.0 83.15.52.161
ip route 83.15.52.162 255.255.255.255 83.15.52.161
ip route 83.15.52.164 255.255.255.255 Tunnel3
deny   ip 192.168.0.0 0.0.255.255 any
deny   ip 10.0.0.0 0.255.255.255 any log
permit ipinip any any
permit icmp any any
ip access-list extended vlan4_acl_in
remark pristup do tech siete IT a BIELYR na intelex BEGIN
permit ip host 10.1.1.10 host 192.168.254.3
permit ip host 10.1.1.10 host 192.168.254.100
permit ip host 10.1.1.4 host 192.168.254.3
permit ip host 10.1.1.4 host 192.168.254.100
remark pristup do tech siete  IT na intelex END
permit ip host 10.1.1.2 192.168.254.0 0.0.0.255
permit ip 192.168.252.0 0.0.0.255 10.1.0.0 0.0.255.255 log
permit ip 192.168.254.0 0.0.0.255 192.168.254.0 0.0.0.255
permit ip 10.2.0.0 0.0.255.255 10.1.0.0 0.0.255.255
permit ip 10.1.0.0 0.0.255.255 10.1.0.0 0.0.255.255
permit ip 10.1.0.0 0.0.255.255 10.2.0.0 0.0.255.255
permit ip 10.1.0.0 0.0.255.255 192.168.252.0 0.0.0.255
permit ip host 10.1.1.2 83.168.174.160 0.0.0.15
permit ip host 10.1.1.2 any
ip access-list extended vlan4_acl_out
remark pristup do tech siete IT a BIELYR na intelex a PTZ  BEGIN
permit ip host 192.168.254.3 host 10.1.1.10
permit ip host 192.168.254.3 host 10.1.1.4
permit ip host 192.168.254.100 host 10.1.1.4
permit ip host 192.168.254.100 host 10.1.1.10
remark pristup do tech siete IT na intelex PTZ END
permit ip 192.168.254.0 0.0.0.255 host 10.1.1.2
permit ip 192.168.252.0 0.0.0.255 host 10.1.1.2
permit ip 10.1.0.0 0.0.255.255 192.168.252.0 0.0.0.255 log
permit ip any host 10.1.1.2
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 192.168.254.0 0.0.0.255
access-list 100 permit ip 192.168.254.0 0.0.0.255 83.15.52.160 0.0.0.7
access-list 100 permit ip 192.168.128.0 0.0.0.255 83.15.52.160 0.0.0.7
access-list 100 permit ip 192.168.250.0 0.0.0.255 83.15.52.160 0.0.0.7
access-list 100 permit ip 192.168.252.0 0.0.0.255 83.15.52.160 0.0.0.7
access-list 100 permit ip 192.168.253.0 0.0.0.255 83.15.52.160 0.0.0.7
access-list 102 deny   gre host 192.168.254.13 host 83.15.52.161
access-list 102 deny   ip any host 10.8.30.240
access-list 102 deny   ip any host 10.8.30.241
access-list 102 deny   ip any host 10.8.31.250
access-list 102 deny   ip any host 10.8.31.251
access-list 102 deny   ip any host 10.8.31.252
access-list 102 deny   ip any host 10.8.31.253
access-list 102 deny   ip any host 10.8.31.225
access-list 102 deny   ip any host 10.100.31.253
access-list 102 deny   ip any host 10.1.9.11
access-list 102 deny   ip any host 10.12.15.20
access-list 102 deny   ip any host 10.12.24.11
access-list 102 deny   ip any host 10.100.7.74
access-list 102 deny   ip any host 10.100.14.1
access-list 102 deny   ip any host 10.100.14.2
access-list 102 deny   ip any host 10.97.108.90
access-list 102 deny   ip any host 10.97.108.91
access-list 102 deny   ip any host 10.97.108.94
access-list 102 deny   ip any host 172.18.1.12
access-list 102 deny   ip any host 172.18.1.13
access-list 102 deny   ip any host 10.106.225.2
access-list 102 deny   ip 192.168.250.0 0.0.0.255 192.168.250.0 0.0.0.255
access-list 102 deny   udp any eq domain any eq domain
access-list 102 permit ip 192.168.128.0 0.0.0.255 any
access-list 102 permit ip 192.168.250.0 0.0.0.255 any
access-list 102 permit ip 192.168.251.0 0.0.0.255 any
access-list 102 permit ip 192.168.252.0 0.0.0.255 any
access-list 102 permit ip 192.168.254.0 0.0.0.255 any
access-list 102 permit ip 10.1.1.0 0.0.0.255 any
match interface Vlan11
13 Replies 13
its like dns problem
Rather, it will be a problem in routing and nat translation. I actually need it, when the computer with the address "192.168.254.102" enter app.example.com so requests routed to newPORTAL and returned to newROUTER.
The easiest way would be to create an internal dns record for app.example.com that points to 10.1.1.2
Could you write me how to create internal dns record. I have my own physical dns server. DNS record app.example.com (83.15.52.165) is correct. It does not cause me complications when accessing the internet?
So external requests for app.example.com are being resolved on your internal DNS servers?
No, external requests are resolved on external DNS servers. Internal on internal, if not found, request are resolved on external DNS.
But I do not know whether this will help me. An application is collected by circuit cameras, even if set at source for cameras address 83.15.52.165:4510, then when i connect to the applicaton by 10.1.1.2, i don't see any records, but he 83.15.52.165 yes.
So you can't even connect to 10.1.1.2:4510 from inside the LAN (Same subnet)?
If you set a source 10.1.1.2:4510, then camera records are unavailable for people to connect from the internet, but from internal network yes. Therefore, if I knew how to get to app.example.com from the internal network as from the Internet
so the problem was solved
I need to accomplish when we enter app.example.com from the internal network, so my request will go in order: newROUTER -> Newport -> 83.15.52.165 (NAT 10.1.1.2). It will look like I come from the internet.
I'm asking if you can connect to 10.1.1.2:4510 from inside the LAN (Same subnet)? If so, just create an A record on your internal DNS server that points app.example.com to 10.1.1.2
Internet users wont be able to access 10.1.1.2 natively since it is a private address.
We can do this another way and through the router but it is more complicated.
James
Yes, from inside the LAN i can connect to 10.1.1.2:4510.
create the record in your internal DNS server then assign it as primary DNS server in TCP/IP properties and put the external one as secondary.
Regards.
Alain
you can do from local pc to edit the hosts file
C:\Windows\System32\drivers\etc\hosts
open with notepad (administrator priv)
add this mapping and save file
10.1.1.2    app.example.com
just for make sure its dns problem
Thanks for responding. Unfortunately dns record nevyrisiel my problem.
I need to accomplish when we enter app.example.com from the internal network, so my request will go in order: newROUTER -> NewPORTAL -> 83.15.52.165 (NAT 10.1.1.2). It will look like I come from the internet.
Now it just translates to newROUTER. I need to redirect it to Newport, and then returned to newRouter.
