nat id order of priority
If I have multiple Nat's for the same interface, will they be matched in order by the lowest nat-id first (other than 0)
It will, but not because of nat-id order (I believe), it will because access list 2 is a longer match.
6 Replies 6
That list doesn't show the order of multiple nats.
I have:
nat (inside) 2 access-list list_1
nat (inside) 3 access-list list_2
access-list list_2 extended permit ip 10.100.0.0 255.255.0.0 host 65.1.1.1
access-list list_3 extended permit ip 10.100.0.0 255.255.0.0 any
will list 2 be used first if going to host 65.1.1.1 in EVERY case because the nat-id is lower than the other nat
thanks
carlos fernandez
The NAT will match the global, which is mapped to the ACL. Are you saying you have multiple globals assigned to an interface and the ACL's have the same source and you want to know which will happen first?
yes. forgot the global cmds
global (outside) 2 65.2.2.2
global (outside) 3 65.3.3.3
If I am trying to get to 65.1.1.1, will my global source always be 65.2.2.2 because of nat-id order
thanks,
carlos
just thought of this
what I need is
access-list list_3 extended deny ip 10.100.0.0 255.255.0.0 host 65.1.1.1
access-list list_3 extended permit ip 10.100.0.0 255.255.0.0 host 65.1.1.1
carlos
