NAt inside to inside interface
MarcinChameleon
Hi All,
A bit of problem with NATting  - ASA 5500 ASDM 6.2.
I have 3 interfaces: ouside, inside, inside1. Outside routes to inside interface, where both interfaces are on public IPs, so no nat control.
The new inside1 interface I want to be on oriv network 10.100.10.0/24. Now I want to NAT public IP from inside interaface to priv IP on inside2.
Basically NATTing must occur between inside and inside2 - on priv IP there is web server.
Can I do somehow without nat enabling command? I just need NAT for few IPs.
TIA for any help.
Marcin
if you want the device to be available from the outside - you need to:-
1) Allow access via an access-list - as the outside is security 0 and Inside1 is security 100
2) You need to have a NAT in place - you could peform PAT on the outside - of try and use the same NAT IP as the inside so something like
static (Inside1,outside) 83.89.92.250 10.100.10.2 netmask 255.255.255.255
20 Replies 20
andrew.prince
Level 11
Level 11
afaik and can remember the nat control is only required when you are going from a higher security interface to a lower security interface. Without nat control - you still should be able to configure a translation between two interfaces with the same security level?
Just double checked an old config - and you can still configure NAT in the normal way even with nat-control turned off.
Hi, thanks for reply.
I can confirm both inside interafces are on 100 security level. I want simple 1 to 1 IP translation.
So should I go like that:config #static (inside,inside1) ip_of_inside1 ip_of_inside netmask 255.2552.255.255???
Does it make any difference, if inside interface is on vlan, and inside1 interface is on native?
yes that should work, and the vlan to native should be ok
I did that. I cannot browse to web on server on inside1 or I cannot browse internet being on that server.
Any ideas?
TIA
what are you actually trying to do, do you want the server on inside 1 to have an ip address in the same range of the inside?
Outside int is on public /30 network and routes to inside also public network /27 network.
Now, inside1 interface is on 10.100.10.0/24 priv network range. (as I mentioned before inside and inside1 are both on security 100)
So I want NAT only few IPs from inside (/27) to priv range on inside1.
Should this be doable?
So you have configured your nat - but it is not working.  Did you configure the setting to allow traffic from 2 interfaces with the same security level??
same-security-traffic permit inter-interface
Yes,
I have:
same-security-traffic permit inter-interface...and
same-security-traffic permit intra-interface
Post your NAT & Interface Config
Here we go:
interface Ethernet0/0.21
description inside
nameif Inside
security-level 100
ip address 83.89.38.193 255.255.255.192
interface Ethernet0/0.23
description outside
nameif Outside
security-level 0
ip address 83.89.92.46 255.255.255.252
interface Ethernet0/1
description For NATting
nameif inside1
security-level 100
ip address 10.100.10.1 255.255.255.0
access-list Inside1_access_in extended permit object-group DM_INLINE_PROTOCOL_1 83.89.38.193 255.255.255.192 host 10.100.10.2
access-list Inside1_access_in extended permit ip any host 10.100.10.2
static (Inside,Inside1) 10.100.10.2 83.89.92.250
netmask 255.255.255.255 dns
static (Inside1,Inside) 83.89.92.250 10.100.10.2 netmask 255.255.255.255 dns
route Outside 0.0.0.0 0.0.0.0 83.89.92.45 1
service-policy global_policy global
Remove
static (Inside,Inside1) 10.100.10.2 83.89.92.250 netmask 255.255.255.255 dns
The correct NAT is
Thanks for that but no luck. I even tried to ping from server on inside net to server with IP 10.100.10.2 - no luck, and from inside net server I cannot even ping interface IP of 10.100.10.1
Of course I can ping from 10.100.10.2 to 10.100.10.1, this seems to be fine.
After applying this:
static (Inside1,Inside) 83.89.92.250 10.100.10.2 netmask 255.255.255.255 - on ASDM it appears as inside1 is original source and inside as translated. I am assuming that's correct.
But, still doesn't work.
There is some joy!
I can ping from servers on inside to inside1 pinging
83.89.92.250
NAT is working because I delete rule I could not ping , created NAT rule again and was working
But still cannot browse to 83.89.92.250 aka 10.100.10.2 from outside. ON outside int access rules allow any trafic on port 80 to any on inside int. Do you think I should allow to inside1 as well, or with NATting this should not be necesary?
