NAT Issue for HTTP Request
dhavaltandel
Hello All,
We have scenerion like,
CLOUD-----CISCO 2621------LAN (LUNIX WEB SERVER & Other Windows Client)
Now we have setup the webserver very well and its working fine too. but issue here is we can not browse the website what we are running locally, as well if we try to access the website from out side we can do so.
additionally if i type ping mysite.com than it also resolves my public ip address.
We have one public IP and the same we are using by utilizing the NAT technology. We have forwarded port number, 80, 110, 25, 53(tcp, udp).
we are using default route for internet browsing using same ip address..
Is there any other config required.....?
Dhaval Tandel
ahmednaas
Level 4
Level 4
Can you post your config?
Hello All,
Thanks for takin interest, here is the configuration.
Dhaval Tandel
You apply an access-group 121 to Fa0/1 but I don't see the corresponding access-list?
HI,
i did remove the access-list from f0/1, even its not working..
thanks
dhaval tandel
