NAT Issue
eknell
I am running PAT on our core 7609 for all our private IP customers. For some reason I am constantly get a "%IPNAT-4-ADDR_ALLOC_FAILURE: Address allocation failed for 10.192.32.21, pool Inat might be exhausted" error message for one particluar ip. I know I haven't exhausted my NAT/PAT table, and I only seem to get the message on the same IP all the time.
Here is my NAT (PAT) config:
ip nat pool Inat x.x.238.2 x.x.238.6 prefix-length 29
ip nat inside source list 3 pool Inat overload
access-list 3 permit 10.190.0.0 0.0.255.255
access-list 3 permit 10.180.0.0 0.0.255.255
access-list 3 permit 10.189.0.0 0.0.255.255
access-list 3 permit 10.192.0.0 0.0.255.255
access-list 3 permit 10.194.0.0 0.0.255.255
access-list 3 permit 10.2.0.0 0.0.0.255
access-list 3 permit 10.32.0.0 0.0.255.255
access-list 3 permit 10.64.0.0 0.0.255.255
access-list 3 permit 10.128.0.0 0.0.255.255
access-list 3 permit 172.16.1.0 0.0.0.63
ET7609#sho ip nat st
Total active translations: 4638 (1 static, 4637 dynamic; 4634 extended)
Outside interfaces:
POS4/0/0, POS4/1/0
Inside interfaces:
Vlan1, Vlan15
Hits: 35298003 Misses: 815345
Expired translations: 814176
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 3 pool Inat refcount 4637
pool Inat: netmask 255.255.255.248
start x.x.238.2 end x.x.238.6
type generic, total addresses 5, allocated 4 (80%), misses 280
Ethan
murabi
Level 4
Level 4
This message indicates that an address could not be allocated from the
IP NAT pool. This condition can cause a translation failure and might
result in packets being dropped. The counter for missed packets will be
incremented.
Recommended Action: Determine if the NAT pool has been exhausted. To
reuse any existing addresses in the NAT pool for new packet flows, clear
the current NAT entries using the clear ip nat translation command.
Note: This will cause a momentary hit to users while the nat table is rebuilt.
