NAT not translating
ildar94
Hi all. I have problem with nat and i dont find problem, two router where nat work and 1 rouret with dont working nat.
Please help me.
My topology:
config in problem router:
ip dhcp excluded-address 10.200.16.1
ip dhcp excluded-address 10.200.32.1
ip dhcp excluded-address 10.200.48.1
ip dhcp excluded-address 10.200.64.1
ip dhcp pool sub-vlan10
network 10.200.16.0 255.255.240.0
default-router 10.200.16.1
dns-server 82.142.150.45
domain-name isp_vrn.ru
ip dhcp pool sub-vlan20
network 10.200.32.0 255.255.240.0
default-router 10.200.32.1
ip dhcp pool sub-vlan30
network 10.200.48.0 255.255.240.0
default-router 10.200.48.1
domain-name ips_vrn.ru
ip dhcp pool sub-vlan40
network 10.200.64.0 255.255.240.0
default-router 10.200.64.1
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1524775K-
spanning-tree mode pvst
interface GigabitEthernet0/0
ip address 46.32.150.65 255.255.255.252
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip address 10.200.16.1 255.255.240.0
ip nat inside
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
ip address 10.200.32.1 255.255.240.0
ip nat inside
interface GigabitEthernet0/1.30
encapsulation dot1Q 30
ip address 10.200.48.1 255.255.240.0
ip nat inside
interface GigabitEthernet0/1.40
encapsulation dot1Q 40
ip address 10.200.64.1 255.255.240.0
ip nat inside
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 46.32.150.66
ip flow-export version 9
access-list 1 permit 10.240.0.0 0.0.255.255
I dont understand, why adresses don't translated?
Also i Have another rourer where nat working.
no ip address
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/0.100
encapsulation dot1Q 100
ip address 10.10.10.1 255.255.255.0
ip helper-address 10.10.1.2
ip access-group buh-acl out
ip nat inside
interface GigabitEthernet0/0.200
encapsulation dot1Q 200
ip address 10.10.20.1 255.255.255.0
ip access-group mng-acl out
ip nat inside
interface GigabitEthernet0/0.300
encapsulation dot1Q 300
ip address 10.10.30.1 255.255.255.0
ip access-group tech-in in
ip access-group tech-acl out
ip nat inside
interface GigabitEthernet0/0.500
encapsulation dot1Q 500
ip address 10.10.50.1 255.255.255.0
ip access-group sales-in in
ip access-group sales-in out
ip nat inside
interface GigabitEthernet0/0.999
encapsulation dot1Q 999
ip address 10.10.99.1 255.255.255.0
ip access-group dir-acl out
ip nat inside
interface GigabitEthernet0/0.1000
encapsulation dot1Q 1000
ip address 10.10.1.1 255.255.255.0
ip nat inside
ip address 46.32.130.65 255.255.255.252
ip nat outside
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan100
mac-address 00e0.f99a.0d01
no ip address
ip nat inside
interface Vlan1000
mac-address 00e0.f99a.0d02
no ip address
ip nat inside
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 46.32.130.66
ip access-list extended sales-in
deny ip 10.10.10.0 0.0.0.255 10.10.50.0 0.0.0.255
deny ip 10.10.20.0 0.0.0.255 10.10.50.0 0.0.0.255
deny ip 10.10.30.0 0.0.0.255 10.10.50.0 0.0.0.255
deny ip 10.10.99.0 0.0.0.255 10.10.50.0 0.0.0.255
permit ip any any
ip access-list extended buh-acl
deny ip 10.10.20.0 0.0.0.255 10.10.10.0 0.0.0.255
deny ip 10.10.30.0 0.0.0.255 10.10.10.0 0.0.0.255
deny ip 10.10.50.0 0.0.0.255 10.10.10.0 0.0.0.255
deny ip 10.10.99.0 0.0.0.255 10.10.10.0 0.0.0.255
permit ip any any
ip access-list extended tech-acl
deny ip 10.10.10.0 0.0.0.255 10.10.30.0 0.0.0.255
deny ip 10.10.20.0 0.0.0.255 10.10.30.0 0.0.0.255
deny ip 10.10.50.0 0.0.0.255 10.10.30.0 0.0.0.255
deny ip 10.10.99.0 0.0.0.255 10.10.30.0 0.0.0.255
permit ip any any
ip access-list extended dir-acl
deny ip 10.10.10.0 0.0.0.255 10.10.99.0 0.0.0.255
deny ip 10.10.20.0 0.0.0.255 10.10.99.0 0.0.0.255
deny ip 10.10.30.0 0.0.0.255 10.10.99.0 0.0.0.255
deny ip 10.10.50.0 0.0.0.255 10.10.99.0 0.0.0.255
permit ip any any
ip access-list extended mng-acl
deny ip 10.10.10.0 0.0.0.255 10.10.20.0 0.0.0.255
deny ip 10.10.30.0 0.0.0.255 10.10.20.0 0.0.0.255
deny ip 10.10.50.0 0.0.0.255 10.10.20.0 0.0.0.255
deny ip 10.10.99.0 0.0.0.255 10.10.20.0 0.0.0.255
permit ip any any
access-list 1 permit 10.10.0.0 0.0.255.255
6 Replies 6
Jaderson Pessoa
as you can see, the default gateway on your router is not pingable, check this connection firstly.
"ip route 0.0.0.0 0.0.0.0 46.32.150.66" << this address is not available according your attached files.. check it firstly and try again.
1. Check if both routers if their interfaces are up/up.
2. Check if the address is correctly on both routers.
3. Check if the connection is establish pinging it.
Jaderson Pessoa
*** Rate All Helpful Responses ***
config from router 46.32.150.66:
interface GigabitEthernet0/0/0
ip address 192.168.1.10 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/0/1
ip address 46.32.150.66 255.255.255.252
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router bgp 5
bgp log-neighbor-changes
no synchronization
neighbor 192.168.1.1 remote-as 2
neighbor 192.168.1.20 remote-as 3
network 46.32.150.64 mask 255.255.255.252
ip classless
ping from problem router to interten over gateway successfull.
Could you post here the full config from both routers?
That has issue with nat and that is current gateway .64 network.
Jaderson Pessoa
looking at your configuration, it seems to me that the access list:
does not match any of the configured IP addresses on the problem router. Change it to:
access-list 1 permit 10.200.0.0 0.0.255.255
Ooo, sure. Thank you a lot. I mixed up the second octet of the network with a mask and don't see)))).
So it is working now ?
