ā12-02-2015 06:08 PM - edited ā03-05-2019 02:51 AM
Can someone tell me if its possible to do this and if so how.
I need to setup a gre tunnel between two routers and tunnel multicast over a WAN.
When the packets enter the tunnel the source address is 172.31.x.x group 239.252.x.x
when they exit the tunnel on the receive side i need the packets
to have a source address of hte tunnel interface with teh same group.
I can setup the tunnel and get the multicast through etc.
is there a way to NAT the traffic as it exits the tunnel to the new source address ?
ā12-04-2015 04:49 PM
Hi Jeffrey,
I think that is not possible , because GRE is a portless protocol , there is not source or destination port on the connection , just the protocol 47.
You might try a solution as GRE over IPSEC to be able to NAT the IPs.
Hope it helps
-Randy-
ā09-28-2018 10:50 AM
It can be done. Look at multicast service reflection.
ā09-28-2018 02:28 PM
which PIM mode are you using to get the multicast traffic over the GRE tunnel ? I want to lab the suggestion made below about Multicast Service Reflection, the only restriction is that it doesn't work with PIM dense mode...
ā10-14-2018 07:46 AM
