NAt ouside NOK
yavuz.ozdemir
Hello Dears,
I'm trying to set up a NAT outside on my vrf router but it doesn't work.
I have a pool that I want to NAT to a IP
But on my router, I can only NAt from a pool to a poo of IP adresses
Ex :
ip nat pool TEST 10.10.10.10 10.10.10.10 length 28
ip nat outside source list ACL-TEST pool TEST vrf TESTLAB
ip access-list standard ACL-TEST
permit x.x.x.0 0.0.15.255
but it doersn't work, can you advice please.
Yavuz
John Blakley
Have you applied nat to your interfaces? What doesn't work?
HTH, John *** Please rate all useful posts ***
yavuz.ozdemir
Yes, I applied the nat on interface.
The NAT works but only for the first ip in the pool.
Normally is not a pool is just a IP but my NAT able only NAT POOL TO POOL
And the overload works only for the NAT Inside and not outside
NAT outside does not have an option of "overload" so you can use a single ip as the translated ip for whole subnet which you are matching in the ACL.
You'd have to use a bigger pool of ip's if you want more than one user/host to be translated with "ip nat outside source" command. This is how Nat Outside is meant to work
you should think of using a fictitious ip subnet pool for outside translation like 10.10.200.0/24. this way you can have 255 simultaneous connections. for more connections you'd have to modify this pool
Check this support forum thread for a config example:
https://supportforums.cisco.com/message/3602792#3602792
