NAT outside to multI Pool
Hello
i have two subnet public ip's
first : 91.x.x.x/25
second : 185.x.x.x/24
i have now create
ip nat pool FirstPool x.x.x.131 x.x.x.x.250 prefix-length 25
ip nat inside source list 1 pool FirstPool overload
access-list 1 permit 172.0.0.0 0.255.255.255
access-list 1 permit 10.0.0.0 0.255.255.255
my first-pool is full
how to use second pool in same nat
5 Replies 5
omz
you could do something like this ...
ip nat pool SecondPool 185.x.x.1 185.x.x.x.254 prefix-length 24
ip nat inside source list 2 pool SecondPool overload
access-list 2 permit 10.0.0.0 0.255.255.255
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/13739-nat-routemap.html#approach
omz
now , i have one isp , give me two ip address
94.x.x.0/25
185.x.x.0/24
in same interface
interface Port-channel1.9
description BAND-IN
encapsulation dot1Q 9
ip address 185.89.98.2 255.255.255.0 secondary
ip address 94.231.199.130 255.255.255.128
ip nat outside
proposed solution should work then ..
Cristian Matei
    There are not too many options on IOS/IOS-XE. You could split the traffic to be NAT'ed between the pools:
ip nat pool FIRST
ip nat inside source list 1 pool FIRST overload
access-list 2 permit 172.0.0.0 0.255.255.255
ip nat pool SECOND
ip nat inside source list 2 pool SECOND overload
Cristian Matei.
