NAT outside to outside
jcarvalh
I have to configure two 4221 (Version 16.9.3) with HSRP and NAT. I have one inside interface and two outside interfaces. I have configured NAT (static source) using route-maps stating which traffic should be met to NAT to different IP addresses. Problem is that I have to NAT an IP address from an outside interface to another outside interface.
Never used "ip nat enable" instead of "ip nat inside/outside" but I believe that "ip nat enable" would help me achieve my goals... problem is that 4221 does not support "ip nat enable". Because of this I have to find another way and I hope you guys can help me.
Thanks and regards.
Joao Carvalho
jcarvalh
More specifically
I configured ip nat outside source static tcp 10.10.6.50 3389 10.250.36.245 3389 redundancy Inside extendable
10.10.6.50 is real IP address behind g0/0 (ip nat outside configured)
If someone tries to RDP to 10.250.36.245 coming from g0/1 (also configued as ip nat outside) will he be able to do it?
Why do need to do that - can you elaborate on what your trying to achieve?
Kind Regards
Paul
