ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Beginner
NAT problem ISR4431, connect to internet but very slow
Hello. I have problems with ISR4431 with I have configured as internet edge, but it seem like NAT works but the speed is very slow. When I use the public IP without NAT it connect to internet very fast but when I use NAT and configured in my PC connected to ISR4431 with a privet IP then the internet turn slower. Also the speedtest doesn't work, it shows latency failure.
Somebody help me !!!
5 REPLIES 5
Highlighted
Beginner
Re: NAT problem ISR4431, connect to internet but very slow
I'd say the first thing you need to do is paste a show run so ppl can see what and how your configured.
Highlighted
VIP Mentor
make sure your basic configuration looks similar to the one below (important parts marked in bold, IP addressing is arbitrary):
no platform punt-keepalive disable-kernel-core
hostname ISR4331
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
ipv6 multicast rpf use-bgp
redundancy
mode none
interface GigabitEthernet0/0/0
description Link to ISP
ip address 79.77.67.65 255.255.255.252
ip nat outside
negotiation auto
interface GigabitEthernet0/0/1
description LAN
ip nat inside
negotiation auto
interface GigabitEthernet0/0/2
no ip address
negotiation auto
interface GigabitEthernet0/0/3
no ip address
negotiation auto
vrf forwarding Mgmt-intf
no ip address
negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 79.77.67.66
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
stopbits 1
line vty 0 4
login
end
Highlighted
Beginner
Hello. Thank you for your answer. The configuration in ISR4431 is the same as you showed.
Highlighted
Beginner
Please give us the results of the following commands:
show process cpu sorted
show process memory sorted
show logs -> it will be important during the day when you have problems
show int wan_int_id | i err
show int wan_int_id | i duplex
Thank you
Highlighted
VIP Mentor
Hello
Can you confirm what dns servers the clients are pointing too?
Have you tried using a ip address instead of a dns FQDN just to to see if the response is any better?
what software version is running on the rtr please?
What speedtest are you using?
kind regards
Paul
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future
