Join Customer Connection to register!
1346
Boris Simunko
Beginner
NAT problem, [NAT: translation failed (E)]
hello!
i have a problem on a 1812 router in NATing to the outside interface.
the config:
Router(config)#do show run
Building configuration...
Current configuration : 1447 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
logging buffered 20000
no aaa new-model
dot11 syslog
ip cef
archive
log config
  hidekeys
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0
ip address 1.1.1.1 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
no ip address
ip nat outside
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
interface Vlan5
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet1
no ip http server
no ip http secure-server
ip nat inside source route-map NAT interface FastEthernet1 overload
ip access-list extended NAT_ADRESE
permit ip any any
route-map NAT permit 1
match ip address NAT_ADRESE
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
password a
login
transport input telnet
line vty 5 15
password a
login
end
when i try to telnet to the fa 0 interface (1.1.1.1) from a directly connected PC (1.1.1.2) i get this debug output:
Router#
*Nov  3 09:29:30.359: IP: tableid=0, s=1.1.1.2 (FastEthernet0), d=1.1.1.1 (FastEthernet0), routed via RIB
*Nov  3 09:29:30.359: IP: s=1.1.1.2 (FastEthernet0), d=1.1.1.1 (FastEthernet0), len 52, rcvd 3
*Nov  3 09:29:30.359: IP: tableid=0, s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), routed via FIB
*Nov  3 09:29:30.359: IP: s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), len 44, sending
*Nov  3 09:29:30.359: NAT: translation failed (E), dropping packet s=1.1.1.1 d=1.1.1.2
Router#
*Nov  3 09:29:32.359: IP: tableid=0, s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), routed via FIB
*Nov  3 09:29:32.359: IP: s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), len 44, sending
*Nov  3 09:29:32.359: NAT: translation failed (E), dropping packet s=1.1.1.1 d=1.1.1.2
Router#
*Nov  3 09:29:33.363: IP: tableid=0, s=1.1.1.2 (FastEthernet0), d=1.1.1.1 (FastEthernet0), routed via RIB
*Nov  3 09:29:33.363: IP: s=1.1.1.2 (FastEthernet0), d=1.1.1.1 (FastEthernet0), len 52, rcvd 3
*Nov  3 09:29:33.363: IP: tableid=0, s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), routed via FIB
*Nov  3 09:29:33.363: IP: s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), len 40, sending
*Nov  3 09:29:33.363: NAT: translation failed (E), dropping packet s=1.1.1.1 d=1.1.1.2
Router#
*Nov  3 09:29:36.359: IP: tableid=0, s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), routed via FIB
*Nov  3 09:29:36.359: IP: s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), len 44, sending
*Nov  3 09:29:36.359: NAT: translation failed (E), dropping packet s=1.1.1.1 d=1.1.1.2
Router#
*Nov  3 09:29:39.359: IP: tableid=0, s=1.1.1.2 (FastEthernet0), d=1.1.1.1 (FastEthernet0), routed via RIB
*Nov  3 09:29:39.359: IP: s=1.1.1.2 (FastEthernet0), d=1.1.1.1 (FastEthernet0), len 48, rcvd 3
*Nov  3 09:29:39.359: IP: tableid=0, s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), routed via FIB
*Nov  3 09:29:39.359: IP: s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), len 40, sending
*Nov  3 09:29:39.359: NAT: translation failed (E), dropping packet s=1.1.1.1 d=1.1.1.2
Router#
*Nov  3 09:29:44.359: IP: tableid=0, s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), routed via FIB
*Nov  3 09:29:44.359: IP: s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), len 44, sending
*Nov  3 09:29:44.359: NAT: translation failed (E), dropping packet s=1.1.1.1 d=1.1.1.2
this is very strange to me because the NAT statement refers to the access-list which permits all ip traffic!
then i discovered that when i edit the access-list and remove the permit statement and only have the deny one
deny   ip any any log
everything works fine:
Router#
*Nov  3 09:31:01.175: IP: tableid=0, s=1.1.1.2 (FastEthernet0), d=1.1.1.1 (FastEthernet0), routed via RIB
*Nov  3 09:31:01.175: IP: s=1.1.1.2 (FastEthernet0), d=1.1.1.1 (FastEthernet0), len 52, rcvd 3
*Nov  3 09:31:01.175: IP: tableid=0, s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), routed via FIB
*Nov  3 09:31:01.175: IP: s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), len 44, sending
*Nov  3 09:31:01.175: IP: s=1.1.1.2 (FastEthernet0), d=1.1.1.1 (FastEthernet0), len 40, rcvd 3
*Nov  3 09:31:01.175: IP: s=1.1.1.2 (FastEthernet0), d=1.1.1.1 (FastEthernet0), len 46, rcvd 3
*Nov  3 09:31:01.175: Telnet6: 1 1 251 1
*Nov  3 09:31:01.179: TCP6: Telnet sent WILL ECHO (1)
*Nov  3 09:31:01.179: Telnet6: 2 2 251 3
Router# 09:31:01.179: TCP6: Telnet sent WILL SUPPRESS-GA (3)
*Nov  3 09:31:01.179: Telnet6: 80000 80000 253 24
*Nov  3 09:31:01.179: TCP6: Telnet sent DO TTY-TYPE (24)
*Nov  3 09:31:01.179: Telnet6: 10000000 10000000 253 31
*Nov  3 09:31:01.179: TCP6: Telnet sent DO WINDOW-SIZE (31)
*Nov  3 09:31:01.179: IP: tableid=0, s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), routed via FIB
*Nov  3 09:31:01.179: IP: s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), len 52, sending
*Nov  3 09:31:01.179: IP: s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), len 82, sending
*Nov  3 09:31:01.179: IP: tableid=0, s=1.1.1.2 (FastEthernet0), d=1.1.1.1 (FastEthernet0), routed via RIB
*Nov  3 09:31:01.179: IP: s=1.1.1.2 (FastEthernet0), d=1.1.1.1 (FastEthernet0), len 55, rcvd 3
*Nov  3 09:31:01.179: TCP6: Telnet received DO SUPPRESS-GA (3)
*Nov  3 09:31:01.179: TCP6: Telnet received WILL TTY-TYPE (24)
*Nov  3 09:31:01.179: Telnet6: Sent SB 24 1
*Nov  3 09:31:01.179: IP: s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), len 46, sending
*Nov  3 09:31:01.179: TCP6: Telnet received DO ECHO (1)
*Nov  3 09:31:01.179: TCP6: Telnet received WILL WINDOW-SIZE (31)
*Nov  3 09:31:01.179: Telnet6: recv SB NAWS 157 67
*Nov  3 09:31:01.183: IP: tableid=0, s=1.1.1.2 (FastEthernet0), d=1.1.1.1 (FastEthernet0), routed via RIB
*Nov  3 09:31:01.183: IP: s=1.1.1.2 (FastEthernet0), d=1.1.1.1 (FastEthernet0), len 40, rcvd 3
*Nov  3 09:31:01.183: IP: s=1.1.1.2 (FastEthernet0), d=1.1.1.1 (FastEthernet0), len 51, rcvd 3
*Nov  3 09:31:01.183: Telnet6: recv SB 24 0 vt100
*Nov  3 09:31:01.391: IP: tableid=0, s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), routed via FIB
*Nov  3 09:31:01.391: IP: s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0), len 40, sending
note that this is a lab router with a very limited configuration, i have this problem on a real production router, but only when i try to login to the router from the outside, otherwise all internet traffic works perfectly (of course, the access-list  is more similar to the one when the login traffic is refused because of the failed NAT translation)
4 REPLIES 4
John Blakley
Advisor
Your NAT statement needs to be changed:
to:
ip nat inside source route-map NAT interface FastEthernet0 overload
John
HTH, John *** Please rate all useful posts ***
well, that's a little embarasing....i fixed it, NAT translation works fine now, but the problem is still here, i get connection time out on the telnet client (SecureCRT), which does not happen when the source list for NAT has only the deny ip any any statement
No need to be embarrassed...you should see some of my posts
Okay, try this acl instead:
deny ip host 1.1.1.1 any
permit ip any any
that worked!
but (there is always a but!), in this case we are talking about a lab router with a static "outside" address. the situation that i actually have is a router with a dialer interface connected to the outside, and a private subnet on the inside which i want to NAT to the internet (overload the dialer interface). as soon as i enter any permit statement in the acl that define the addresses to be NATed, the remote login to the router (i connect to the public IP on the dialer interface) breaks, and all i get is a connection time-out error
