NAT Problem
usman792
i have NAT pool confiugre in my router. my traffice goes through .5 ip address. i want my traffic goes .6 ip address. Is there any command router use NAT pool next ip address .
thanks
Usman
pkhatri
Level 11
Level 11
Hi Usman,
The only way to do so is to start your NAT pool with the .6 address. When using overloading, NAT is likely to continue using the first address in the pool unless it exhausts the port numbers in the appropriate range for that address.
Hope that helps - pls do remember to rate posts that help.
Paresh
