NAT Query
amolak_cisco
Hi All,
I have a query as follows:
X NET (100.200.1.X) ------[(NAT outside int)-NAT Router-(NAT inside int)] ------- Y NET (192.168.1.X)
Suppose I have configured NAT to translate 192.168.1.x network to 100.200.1.X.
If I ping/trace from X NET on NATted IP who will answer for that ping reply?
Is it NAT router or destination host of Y NET?
I would be thankful If someone can provide a good documents link on different NAT scenarios.
Thanks & Regards,
Amolak
s.arunkumar
Level 3
Level 3
destination host of Y net if the routing is proper between the network..
u can use this to learn..
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hiad_c/ch20/index.htm
